1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2012 f550 v10 start then stalls
Old 06-30-2022, 11:58 PM
05FAMILYTRUCKSTER's Avatar
05FAMILYTRUCKSTER
05FAMILYTRUCKSTER is offline
4th Gear
I have a 2012 F550 V10, IMT service body. Have owned truck 2 years. Initially started having a erratic idle with no other issues while driving. After several weeks it suddenly stalled while driving and ever since will start right up then stall within a second or two.
Checked DTC's with Forscan. Codes: PCM: P1639:00-28, RCM: U0140:00-08, U3003:16-08, BdyCM: U3003:16-08, B10F1:14-0A, B1313:11-08, U0212:87-08 SCCM: B11D9:16-08 IPC: U3003:16-08 ABS: B1318-20
All codes cleared except PCM would not clear.
At key on throttle body cycles, fuel pump cycles. Checked fuel pressure 50psi. key on, goes to 60 when cranking, once engine stalls returned to 50psi. Checked Fuel Pump Driver Module and found green residue on several pins, cleaned connector and installed new Ford module. No change in condition. Since owned the ignition switch has always been sensitive to bumping in off position.(door chime would momentarily ding and IMT body power relay would cycle on) Installed new ignition switch. Sensitivity solved but stall issue same. Since Fuel filter is part of the pump when ahead and drained tank and dropped it. Found tank remarkably clean inside, installed new Delphi Fuel pump assembly. Installed tank and filed 3/4 full. Same fuel pressure and symptom. Had local tech Scan with Snap ON scanner and only code is PCM code. His research said PCM was corrupted. Order new Ford PCM, installed and programed. Still same problem, but now PCM code gone. Have checked all grounds readily visible. Sprayed throttle body with cleaner. Cleaned MAP sensor.
If anyone has suggestions on what may be going on I welcome any input.
Thanks
Syoungs
Modular V10 (6.8l)
08-13-2023 07:34 AM
bikeman5
12-12-2020 12:57 AM
warwizard40
1978 - 1996 Big Bronco
07-05-2018 04:03 PM
2007sporttrac
09-16-2015 11:38 PM
mooreswm
Modular V10 (6.8l)
07-27-2015 06:16 PM
Quick Reply: 2012 f550 v10 start then stalls
