My truck starts and runs fine cold. after 10 minutes or so of driving, it starts choking and stalls. If you try to start it, it will not. If you wait about 3 minutes, it is fine, starts , and drives ok, for about 3 minutes.
I have replaced, plugs, fuel filter, battery, and a ignition module, as well as cleaned the opening of the throttle body
Ford has ordered a fuel pump which will cost me about $1000 installed.
I am thinking it could be the
-Throttle position Sensor?
-MAF sensor?
-fuel pump?
It puts out code p0191 for low fuel pressure.
Ford is scheduled to install new pump in am, but I don't want to spend a grand if it is just the TPS or MAf?
A grand for a fuel pump?! Is it made of gold and pay your bills for life?! You can buy the pump from any parts supplier and install it yourself. Even with a full tank its fairly easy. And they usually fail on a full tank....Did it at least fix it?
