Fuel pump problems
Old Jun 30, 2022 | 03:07 PM
Estew2006's Avatar
Estew2006
4th Gear
Fuel pump problems
So I have a 2005 4.6 fuel pump wasn't pumping I just replaced the pump and still nothing
So I pulled it back out and checked voltage to the pump I have 12v to the pump when I cycle the key the pumps turns on for just a second and stops as if it already primed then nothing from there.
I still have 12v after the prime sequence. Where should I check next?
Old Jun 30, 2022 | 03:09 PM
projectSHO89's Avatar
projectSHO89
Check the ground circuit for the pump.
If you have battery voltage to the pump .AND. the pump is good .AND. the pump has a proper electrical connection to ground, the pump should run.
Did you check the integrity of the FPDM module?
Old Jun 30, 2022 | 03:15 PM
Estew2006's Avatar
Estew2006
4th Gear
No I haven't checked the drive module yet. If the module is bad would I still have power to the pump checking the 2 wires to the pump connection?
I assume I wouldn't have any power to the pump if it was bad but idk
Old Jun 30, 2022 | 03:22 PM
tbear853's Avatar
tbear853
Look at the FPDM up above the spare on driver side towards front. You can roll under there and see it from below if you unwind the spare, right behind the left rear tire, round crossmember. You can also look through that right rear fender well with a mirror on a stick.
Old Jun 30, 2022 | 03:32 PM
Estew2006's Avatar
Estew2006
4th Gear
So if the drive module is shot it can cause the pump to not pump even though it has 12v to it?
Old Jun 30, 2022 | 07:15 PM
projectSHO89
Certainly, since it supplies both power and ground to the electric pump.
Old Jun 30, 2022 | 10:22 PM
Estew2006's Avatar
Estew2006
4th Gear
Well I got it fired up I had to bypass the drive module by jumping the connections on the drive module connector.
Then whoever had worked on it before had replaced the drive module and pump at one point and both electrical connectors for the drive module and pump where broke so I had to zip tie the pump connector so it would make connection.
I'll have to see if I can get new pigtails for those 2 connectors or tell the owner of the truck to check a junkyard to find good connectors
Old Jul 1, 2022 | 10:25 AM
projectSHO89
Dean06919
Jul 23, 2015 07:01 AM
Prez
1997 - 2003 F150
Apr 21, 2015 09:49 PM
DougMcCarty
1997 - 2003 F150
Mar 25, 2013 05:04 AM
