Fuel pump will not prime?
Old Jul 22, 2015 | 09:35 PM
Dean06919's Avatar
Dean06919
1994 F350, 5.8L, auto, 4x4.
I replaced the front fuel pump with a used pump assembly and completely emptied and cleaned the tank. I added five gallons of gas and turned the key on and off about 30 times. I can hear the pump kick on when I turn the key, but the pump will not move any fuel. The rear pump works fine, but the truck will stall if left to run on the front pump.
Is there a trick to get the pump to prime? Should I add another 5 gallons? Any way to trouble shoot the pump? Suggestions?
Old Jul 23, 2015 | 07:01 AM
subford's Avatar
subford
Sounds like you have the wires swapped.
You have the pump running backwards.
lovemy150's
Jun 7, 2014 05:59 AM
htcsusn
Jan 3, 2007 06:57 AM
fjbcarver
1978 - 1996 Big Bronco
Nov 4, 2004 08:14 AM
dbabin
Jun 28, 2002 05:27 PM
