Fuel pump
Old Jun 25, 2022 | 07:08 AM
Eric Wallin's Avatar
Eric Wallin
1st Gear
Fuel pump
I have a 2003 Excursion 6.8. Is there a repair or fix for the insane fuel pump holder design in the tank?
I got this excursion after it sat for 11 years and the metal ring Ford used to hole the plastic holder to to the tank rusted and the holder broke loose from the tank. I attempted to use water weld to re-stick it to the bottom of the tank but it only lasted about 6months. Any help or ideas would be much appreciated!!!
Old Jun 25, 2022 | 10:19 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by Eric Wallin
.... the metal ring Ford used to hole the plastic holder to to the tank rusted and the holder broke loose from the tank. ....
If you can't find some sort of adhesive for the holder maybe you can run a SS bolt thru the holder and the tank bottom.
HRTKD
All Things Towing
Apr 13, 2024 10:04 PM
TAF
Sep 6, 2019 07:54 PM
old blue 90
Nov 29, 2009 11:03 AM
Tim Young
Dec 5, 2006 09:20 PM
electricsheep
28
Oct 25, 2004 09:14 AM
