quick oil temp question.
Old Jun 24, 2022 | 12:35 PM
THE FISH BAIT's Avatar
THE FISH BAIT
I'm just curious, what would be a "normal engine oil temp" and EOT under sustained load. During my last camping trip I noticed EOT was 209 wile under load and 197~ unloaded. My coolant "idiot" gauge on the dash never moved.
Thanks
Old Jun 24, 2022 | 12:51 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Your EOT observation is right in line with where I would expect to see an efficient cooling system. I would like to offer a couple of quick links for your reading and viewing enjoyment...
Link of some of my EOT in various conditions: https://www.ford-trucks.com/forums/1...l#post20452804
Link from a recent thread: https://www.ford-trucks.com/forums/1...l#post20439504
Also from the Ford Service Manual PC/ED volume...
I hope this helps.
Old Jun 24, 2022 | 01:24 PM
Walleye Hunter's Avatar
Walleye Hunter
Keep in mind...your oil cooler is an oil cooler and your oil is cooled by coolant. Accordingly, your oil temp would have to be higher than your coolant temp.
Old Jun 25, 2022 | 12:30 PM
THE FISH BAIT
Thanks for the info! My EOT under load was was a type-o it should have read 219 not 209. Also forgot to mention that ambient temp was about 102 when I saw these readings. I was just curious because I have never monitored my EOT till recently, and never had an actual temp gauge on my coolant system. I have hauled some fairly heavy loads and never seen any difference in coolant temp on the idiot gauge. I'm not an oil expert but I deal with large turbines and lube oil systems at work. We usually don't worry much about bearing and seal damage till around 275*F. I figured trucks weren't much different. I guess I was just wondering what the range of "normal" for a healthy cooling system looks like.
Old Jun 25, 2022 | 02:25 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Keep in mind please... The with the exception of the transmission cooler, the entire 7.3 Power Stroke cooling system is seriously robust and very capable of its job if properly maintained.
215-220 is an everyday thing here in Texas for oil temp running empty.
Most conventional oil can run 250 all day long without issues to the oil. You need to be above 200 anyway for the contaminates to burn out for at least an hour, longer is better. Synthetic oil is all over the place when it comes to temperature depending on blends and base stocks, however usually between 450 to about 700 or more, please do not run oil that hot.... Your coolant temperature would be uncontrollable at that point anyway. Keep an eye on a proper coolant gauge and a real oil temperature gauge.
When done driving (loaded especially) let the engine idle for a few minutes before shutting down, protects the turbo and cools the entire cooling system some.
Bigtruc
20
Dec 26, 2013 10:24 AM
jayc3169
Jul 25, 2011 03:26 PM
John - NNY
Nov 16, 2007 04:36 PM
Dustball8504
Oct 6, 2007 05:59 PM
jtharvey
Jan 24, 2007 09:37 AM
