Aggressive Tow from Spartan?
Old Oct 6, 2007 | 03:27 PM
Dustball8504's Avatar
Dustball8504
Hey all, I just had a quick question about towing performance with the Agg Tow tune from Spartan. I used it earlier this week and all I had on was a car trailer and a hatchback jetta. Not a big load at all, I did have to pull some decently steep grades and my Power PDA threw the oil temp light, after I switched the gauges around on it I saw the oil temp had hit 228, is this normal or not?
Old Oct 6, 2007 | 03:41 PM
04Xcursion's Avatar
04Xcursion
That's not an unreasonable engine oil temp if your coolant temp was 205-215. If your coolant temp was still down at the 180-190 level and the oil temp was 230 you may have an obstructed oil cooler.
Old Oct 6, 2007 | 03:46 PM
badbrad60's Avatar
badbrad60
If I remember correctly the Oil measures somewhere between 10 -15 degrees hotter than coolant temp. Since the fan cycles between 210-220 coolant temp, that would make the PDA scream all the time on a hard climb. I called Banks when I first got mine, and they told me to raise the oil temp alert to 235 deg. Kinda funny that even at 235 the idiot gauge doesn't even move. ~Brad
Old Oct 6, 2007 | 04:39 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Jason and Brad have this one covered
Engine Oil Temperature will run somewhat hotter under load than than ECT. All of our files will begin to defuel at a temperature caution point of 254 degrees; with an emergency fuel shutdown at 282. You were still within perfectly safe parameters.
Old Oct 6, 2007 | 05:02 PM
blackhat620's Avatar
blackhat620
Dustball8504,
As the others have said, the oil temperature you saw should not be a problem. FMC says that the EOT should be no more than 20F degrees warmer than the ECT. If the EOT is more than 20F warmer than the ECT then this indicates a problem with the EOC as 04Xcursion said. Compare your ECT & EOT to make sure they are within 20F of each other.
IIRC with factory stock programming defuel occurrs at ECT of 227F, EOT of 254F.
Old Oct 6, 2007 | 05:59 PM
Dustball8504
Thanks guys, I just got a little worried when the light went off on the pda!
