Sponsored by: Real Truck
7.3 hard start
Old Jun 24, 2022 | 12:19 PM
mike41a's Avatar
mike41a
4wd High
7.3 hard start
Hi all. 2000 F350, 7.3 diesel. I just completed replacing the HPOP oil (branch) lines from the HPOP to the heads after one blew out. I refilled the crankcase with oil, but didn't refill the HPOP, reasoning it would refill by cranking the engine. Took forever, but it started and ran. checked for leaks, found none.
This truck used to start almost immediately (3-4 seconds crank time), but now if it sits for 20 minutes or more I have to crank 20-30 seconds for it to start. I'm assuming it now has to build oil pressure at the HPOP. Could the HPOP be leaking down now????
Anyway, If anyone of you Guru's have any words of wisdom on this, I'd appreciate any help. Mike
Old Jun 24, 2022 | 04:53 PM
bwguardian's Avatar
bwguardian
Did you remove the check valve out of the HPOP where the lines connect?
Old Jun 26, 2022 | 10:04 PM
mike41a's Avatar
mike41a
4wd High
Update:
I had just started the truck and let it run for a few minutes, but hadn't actually driven it anywhere. On Saturday I towed a 12,000# trailer on a 130 mile round trip. At the event I was going to, I talked to a friend/Ford Master mechanic, and he told me that I just needed to run the **** out of it. On the trip back home it seemed to be back to it's previous power level, and it started like it used to.
Old Jun 26, 2022 | 10:11 PM
DRPS's Avatar
DRPS
Originally Posted by mike41a
Update:
OP... Did the mechanic say why it would take running the engine for so long for it to come back?
I understood there is a reservoir in the HPOP and should fill up rather quickly.
Im glad your issue is solved, but I dont understand why...
Just curious
Old Jun 27, 2022 | 10:05 AM
99powerstrokedF250's Avatar
99powerstrokedF250
It has to do with completely filling the high-pressure oil system. I had a 7.3 that I had to replace injector o-rings on, and when I drained the heads to keep oil from getting into the combustion chambers it took a long while to get those oil lines to refill. For a few starts afterwards it didn't want to start all that well, but I generally drive 20-30 minutes each way to work (at the time it was a bit further) so after a day or two it was fine again.
Old Jun 28, 2022 | 01:18 AM
DRPS's Avatar
DRPS
Originally Posted by 99powerstrokedF250
It has to do with completely filling the high-pressure oil system. .
Thanks for the info
mccloudfam1
Apr 14, 2021 12:28 AM
Benlphil
Apr 22, 2018 12:31 AM
MrCat4974
Jan 5, 2015 10:41 PM
Nighttrain
20
Jul 26, 2010 09:24 PM
motionmarineaudio
Nov 30, 2007 07:44 PM
