00 7.3 won’t start
Old Apr 13, 2021 | 06:17 PM
mccloudfam1's Avatar
mccloudfam1
00 7.3 won’t start
My 00 excursion with a 7.3 in it started dumping oil around hpop. Replaced all lines and fired it up it ran about 10 mins and died, but I still had leak. Rebuilt hpop gaskets and o rings but am only getting 300 psi of oil pressure. Replaced ipr and then hpop. Checked all glow plug system, but it just cranks won’t fire at all. Not sure where to go now?
Old Apr 13, 2021 | 06:41 PM
lpzd's Avatar
lpzd
When you replace the hpop it takes a while for it to fire off initially. Is the hpop res full? How long did you crank to try to start? Made sure Everything is hooked back up?
Old Apr 13, 2021 | 06:43 PM
mccloudfam1
Checked everything twice and cranked on it till batteries went dead, charged and cranked on it a 2nd time till batteries went dead again.
Old Apr 13, 2021 | 07:06 PM
Listor's Avatar
Listor
This can be an issue when you drain all of that oil out of the hpop, refill the Hpop and check your oil lvl, takes time to get things up to pressure again
Old Apr 14, 2021 | 12:28 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Fill the HPOP reservoir and try again with strong batteries. My guess is the LPOP did not fill the reservoir before the batteries went south.
What was the PN on the HPOP gasket? There are early and late versions.
carltonwebb
Nov 8, 2024 09:42 PM
Hardlanding
Apr 13, 2017 09:10 AM
cj_1776
Mar 26, 2017 07:52 PM
goosehunta
Dec 25, 2013 07:21 PM
motionmarineaudio
Nov 30, 2007 07:44 PM
