Fuel Pressure
Old Jun 25, 2022 | 10:29 AM
TooManyToys.'s Avatar
TooManyToys.
That would be great, these trucks are getting old. You may already be thinking about this, but posting what you used can help someone else in the future.
Old Jun 25, 2022 | 11:24 AM
fedspunisher's Avatar
fedspunisher
Test drive i put it to the floor and the lowest it hit was 57psi for split second. So i am hoping this is the end of the story.
Followed your video to a tee. I left the cigarette plug in and used the connector on the pump to start and stop it since it was in the air. No flow from the pump and any good flow i got was frothy leading to possible air intrusion. Based on your post i wiggled the connector for the feed line and the pump would charge pitch and flow would vary. I used a knife to split the factory rubber line off the metal lines just before the pump. Ran 5/16 rubber fuel line between the metal line and metal connector on the pump. Secured then with stainless steel screw type hose clamps.
THANKS for all the help.
Pulling the camper 600 miles this coming weekend. That should prove its fixed.
Old Jun 28, 2022 | 09:38 AM
fedspunisher
@TooManyToys. One last question. Do these symptoms line up with air entering from a faulty connection on the feed line to the pump? Would just like some confidence that I fixed the problem and that it was just intermittent and will rear its ugly head on the 600 miles of pulling the camper this weekend.
Old Jun 28, 2022 | 10:08 AM
TooManyToys.
They would.
But saying IT was the only problem can only be addressed with miles. Eric though he had his problem solved, before he didn't. I'd do an hour or two of driving one evening.
Sea trials.
Agate Flats
Jun 14, 2022 08:22 AM
r___r
28
Dec 28, 2021 04:34 AM
David Fehir
Sep 21, 2019 01:37 PM
suicidecharley
Jun 3, 2016 10:17 AM
gungho351
19
Jan 31, 2007 03:42 PM
