Code 212
Old Jun 25, 2022 | 09:12 AM
Scndsin's Avatar
Scndsin
Glad it worked out & thanks for the report.
Old Jun 25, 2022 | 12:07 PM
rla2005's Avatar
rla2005
Glad you found the fix and reported back.
Old Jun 26, 2022 | 07:50 AM
blacklab1's Avatar
blacklab1
Thanks for the help. I still can't figure out why it ran fine when it was cold.
Old Jun 26, 2022 | 02:21 PM
rla2005's Avatar
rla2005
Poor quality/aged plug wires breakdown when heated.
Open loop air/fuel ratio is also pig rich on these trucks.
Old Jun 27, 2022 | 07:44 AM
blacklab1's Avatar
blacklab1
Is that something that can be corrected?
Old Jun 27, 2022 | 08:23 AM
rla2005's Avatar
rla2005
Not without a tuner. That's the way the system is programmed. Another reason why the thermactor system is designed to inject air directly into the converter to get it up to temperature quickly.
Old Jun 27, 2022 | 08:41 AM
blacklab1's Avatar
blacklab1
The Cats and smog system were gone when I bought the truck.
Old Jun 27, 2022 | 08:48 AM
rla2005's Avatar
rla2005
Great, the computer is still programmed for a very rich mixture at cold start up.
Old Jun 30, 2022 | 09:33 PM
blacklab1's Avatar
blacklab1
Continuing saga.
Have been driving daily. Truck starts, runs, lots of power, shifts fine.
It seems to flatten out at about 2500 rpm. doesn't seem to be missing just seems to dog.
Step on it perks right up then when I back off it seems to flatten out again. Happens on both tanks so not thinking fuel.
Any suggestions??
Old Jul 1, 2022 | 07:39 AM
rla2005's Avatar
rla2005
Both tanks use the same fuel pressure regulator. Verify the fuel pressure at idle and under load. I do not recall if you have checked the base timing?
Old Jul 1, 2022 | 08:13 AM
torq'ta 5 8's Avatar
torq'ta 5 8
2wd, 4wd?(big tires), what is gearing, on drivers door?
Old Jul 1, 2022 | 08:30 AM
blacklab1's Avatar
blacklab1
3.55 gears stock tire size 4x4.
Like I said in the opener I don't have much for diagnostic equipment.
Is there a way to tell if tie engine is stock?
The belt routing sticker under the head says it for a 7.5
Old Jul 1, 2022 | 08:34 AM
  #28
Scndsin's Avatar
Scndsin
You can rent a fuel pressure tester from one of the big 3 parts stores.
You'll have to layout the cash deposit, but it comes back.
Old Jul 1, 2022 | 04:07 PM
  #29
blacklab1's Avatar
blacklab1
I wish! You boys down south got it made. I'm in central British Columbia, half way to Alaska from the border.
Old Jul 1, 2022 | 06:17 PM
  #30
Scndsin's Avatar
Scndsin
Yep, you iz really out there. You got my respect & sympathies.
