Running rough and missing
Old Jun 19, 2022 | 04:26 AM
88f2fitty's Avatar
88f2fitty
5th Gear
I have a 1988 F250 that is was running great after changing all the plugs wires cap and rotor but then I towed my new camper (20 foot bumper pull) from airway heights to post falls which is about 40 miles. It was running real rough and missing and died on its own. The plugs were all fouled bad so I changed just to the plugs to a highly recomended plug (motorcraft) and it ran great again but the only driving I did was to Kingston with my camper another 40 miles. And it’s doing the same thing just not as bad. I did a dump run today without much weight in the back just an old 4.0 motor and trans and some household garbage. Also about 30 miles round trip. It seems to be doing better after that but not by much. Any ideas on what’s going on would be helpful.
Old Jun 19, 2022 | 06:49 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Remove the vacuum line off the fuel pressure regulator to see if the diaphragm is broken allowing unmetered fuel to be drawn into the intake manifold.
Old Jun 20, 2022 | 07:42 AM
88f2fitty's Avatar
88f2fitty
5th Gear
I didn’t think of that. I’ll check it when I get home tonight and give an update, thank you
Old Jun 28, 2022 | 01:38 AM
88f2fitty's Avatar
88f2fitty
5th Gear
I checked it finally without rubbing it first and there wasn’t moisture but when I get a chance I will start it for a bit then check.
Old Jun 30, 2022 | 06:16 PM
88f2fitty's Avatar
88f2fitty
5th Gear
Still no moisture after running it pretty hard for about 20 minutes, any other ideas?
Old Jun 30, 2022 | 06:24 PM
torq'ta 5 8's Avatar
torq'ta 5 8
What engine, 02 sensor still plugged in, codes, even if CEL isnt on?
Old Jun 30, 2022 | 06:25 PM
rla2005's Avatar
rla2005
One of the most common failures of the pressure regulator is a ruptured diaphragm as stated before. Since you are not seeing any fuel leaking the next step is to verify the fuel pressure at idle, idle with the vacuum line removed, then under load.
Fuel pressure at idle should be 30-32 PSI. At idle vacuum line removed should be ~40 PSI. Under load, vacuum line attached, should also increase to 40 PSI range. As the load increases the manifold vacuum lowers which in turn increases fuel pressure.
Old Jul 1, 2022 | 03:12 AM
88f2fitty's Avatar
88f2fitty
5th Gear
I’ll check all that when I get a chance, thank y’all for the help
chaser1602
Mar 9, 2018 07:53 AM
Dr. Dirt
May 26, 2008 08:06 PM
Flexfuel-Dave
1983 - 2012 Ranger & B-Series
Aug 14, 2007 07:23 AM
hotmod046
Apr 12, 2005 10:53 AM
Stevie M
Aerostar
Dec 29, 2003 01:20 PM
