Tuning Help needed!
Old Jun 18, 2022 | 03:17 PM
Conanski's Avatar
Conanski
Originally Posted by G_Real
I'm beginning to feel this may be the best route. Cam and lifters as well I presume?
Yes, new lifters are always required when changing a flat tappet cam.
Question… why do you feel a tuner would not resolving the issue?
Well as I mentioned... one of the "features" of a performance cam is a lumpy unstable idle with lower that stock vacuum. These can be made to work well enough with a manual trans because you either have the clutch engaged or the trans in neutral when the vehicle is stopped, but with an auto it's customary to leave it in drive all the time and it's only the torque converter slip that allows the vehicle to stay statonary with a light brake applied. But that only works with the 650rpm idle these trucks are setup with, even raising the idle speed to 800pm makes it more difficult to hold the vehicle still in gear and that is because the TC is grabbing more. The cam you have is also mismatched to the engine, the stock heads and intake become restrictive after 4000rpm while that cam is designed to make best power at higher rpms. Performance vehicles with auto transmissions often have a higher stall converter because of these cam characteristics. you could do that but now you're changing the transmission because the engine has the wrong cam in it. How does that make any sense? With a tuner you can richen the idle mixture which would help smooth it but it's very likely the idle speed would still have to rise to prevent the stalling, but that creates the other problems I mentioned above.
Old Jun 18, 2022 | 03:26 PM
G_Real's Avatar
G_Real
4wd Low
Originally Posted by sswari
if you go the QH way, do the research on your EEC/ECU to make sure it is supported. I had to learn this lesson the hard way. However, once you figure out what it is you have and where you want to go, the QH is a very viable option.
It has taken me several months, but yesterday, I got it to pass emissions on the first try (Very satisfying). I went from a 5.0 to a 5.8 with MAF update and a odd ball cam. It was the cam that started me down the tuning path, and while I was meandering around lost in the whole business, I ended up with a MAF as well.
Thank you! I am currently researching these different options. You guys are the best, Thank you!
Old Jun 18, 2022 | 03:28 PM
sswari's Avatar
sswari
Good Luck, and keep us Posted. it is always good to hear about the success stories.
Old Jun 18, 2022 | 03:29 PM
G_Real's Avatar
G_Real
4wd Low
AH, yes that makes perfect sense! Thank you
Yes, changing one thing because of another problem would be like bringing home another wife to fix the current… Nevermind. I’ll leave that alone. Lol
I’ve managed to find a Idle Control adjuster close by, the one you’d previously mentioned. I’ll give that a go first as a temp fix and then keep moving forward with a cam swap thereafter.
you guys have been amazing. This dad appreciates you. TY
Old Jun 18, 2022 | 03:33 PM
G_Real's Avatar
G_Real
4wd Low
Thank you, will do!
Lastly… is anyone here able to see the MAF meter in the pictures above? It doesn’t appear that it is there. It appears that only the MAP sensor is there. TIA
Old Jun 18, 2022 | 03:45 PM
sswari's Avatar
sswari
Thank you, will do!
No, you do not have a MAF, It would look like this.
So you are probably stock except for the cam unless they did something else internal to the motor, like roller lifters or the like.
Old Jun 18, 2022 | 04:25 PM
G_Real's Avatar
G_Real
4wd Low
gotcha! Thanks again.
so, moving forward I am going to try the Idle Air adjustment kit, as a temp fix. Though since he doesn’t have a MAF, would it be wise to get one? Would it make sense and is it as easy as adding one?
understanding of course a cam swap is likely the best way to go.
Again, really appreciate all your help!
Old Jun 18, 2022 | 04:56 PM
sswari's Avatar
sswari
NO!!!!!!!!!!!!!!!!!!!!
Unless you want to go down the tunning road!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!! You would have to get a new ECU that supports MAF, Then either modify your current engine harness or buy an overlay to control the injectors and modify parts of your engine bay harness., Then on to the QH and or what every you wish to tune it with then............
Old Jun 18, 2022 | 05:11 PM
yardbird's Avatar
yardbird
You can get the idle adjuster. Just know you will have to shift to neutral every time you stop to keep the rpms up. But, even with that, it's doubtful you will pull enough vacuum to keep the MAP sensor happy.
Old Jun 18, 2022 | 06:26 PM
wwhite's Avatar
wwhite
All Speed Density (SD) EEC-IV are supported with QH and TunerProRT. No need to go MAF.
ramrodder007
Missouri Chapter
Apr 2, 2013 12:54 AM
emjc81402
1978 - 1996 Big Bronco
Jun 25, 2004 04:40 PM
Brown Beast
Mar 15, 2004 08:31 PM
bigred0410e
Jan 21, 2003 12:45 AM
