Sponsored by: Real Truck
Coolant issue
Old Jun 17, 2022 | 02:03 PM
HEATHN's Avatar
HEATHN
8th Gear
Coolant issue
I have a 2015 F250 diesel with 165k. Just recently noticed level was low and I have to keep adding coolant. I do not see any leaks in the coolant system. Anybody know what my next check should be. Note: Its the primary system not the smaller one.
Old Jun 17, 2022 | 03:36 PM
L_R_G's Avatar
L_R_G
6th Gear
How much are you adding and how often are you needing to add it? Do you smell coolant under the hood and/or when it's running? I'm not sure if the 15's have the same turbo coolant line setup as the older models but I know on the older ones that line was prone to leaking and basically impossible to see due to the location.
Old Jun 22, 2022 | 10:35 AM
HEATHN's Avatar
HEATHN
8th Gear
It seems to be about a gallon ever few weeks. I dont smell coolant or see any thing wet and dripping.
Old Jun 22, 2022 | 02:38 PM
FiveOJester's Avatar
FiveOJester
You might have better luck in the 6.7 diesel forum.
Here is the coolant flow diagram for the primary system from the Technician's manual:
nut1605
Dec 11, 2021 02:51 PM
Berriemaas
Sep 14, 2017 07:09 AM
RussB
6.7L Power Stroke Diesel
21
Apr 8, 2014 12:08 PM
state
Aug 21, 2003 04:31 PM
Starratt04
Mar 20, 2003 03:31 AM
