Goodbye and Hello again
Old Jan 25, 2024 | 09:17 AM
CC RIOT's Avatar
CC RIOT
3rd Gear
Originally Posted by NASSTY
It doesn't seem like there's been a a lot of complete breakdowns with the 10 speed. Some just seem to shift clunkier than others. The 10 speed in my 2017 was butter smooth up and down shifting. My 2020 isn't too bad but gets a little clunky on downshifts sometimes. It doesn't bother me too much...probably because I'm used to my old hot rod with a performance built 4 speed with a shift kit and it always shifts firm up and down.
I still prefer the 10 speed over the 6 speed because my 2014 suffered from the lead frame issue. That would really make your butt pucker when you would get up to 45 mph and it would drop down to 1st gear literally locking up the rear wheels.
I have had complete failure on 2 out of the four. 1 was on a 18 Raptor and it shifted from 9th to 1st unexpectedly at 80 mph alsmost causing me to flip the truck over trying to regain control. The second one that failed literally started skippin from 1 to 5 then back to 1 30 seconds latet there was no drive .
Old Jan 25, 2024 | 11:55 AM
SpencerPJ's Avatar
SpencerPJ
Originally Posted by CC RIOT
my last one was fine until I did a maintenace flush then it started shifting hard immediately after leaving the dealership.
I'm not a fan of the flush either.
Some are clunky because the transmission simply needs reset, but of the various F150 things I follow, rarely does the original owner have issues, seems the used 'on lease' have a much higher failure rate, and that's no surprise based off what many that lease tow behind them, it's insane. I'm certainly not defending Ford, but GM has it's woes, I wouldn't own a Ram, and Toyo is about 15 years behind with technology. So it all boils down to the coin flip, lesser of the potential evils, and a prayer.
MICHIGANDER78
Jul 14, 2019 09:14 AM
BullDad
Mar 30, 2011 09:06 AM
1978fordf250
44
Mar 15, 2008 05:01 PM
