Base Coat or Single Stage
Old Jun 16, 2022 | 03:22 PM
daveengelson's Avatar
daveengelson
Rather than have a can of paint mixed for my 65 F100, I only need enough to cover a repair area and came across a paint supplier who offers the same/similar color code (Chamotte Brown) in aerosol cans either base coat or single stage;and I do not know whether to apply a coat of base then a coat of single stage, or only apply one or the other??
Any input would be appreciated!!
Old Jun 16, 2022 | 06:10 PM
Beechkid's Avatar
Beechkid
Ok, what you have to use is whatever the truck was painted with.... meaning if it's a 2 stage BC/CC paint job then you have the 2 stage paint.... otherwise it's going to stick out like a "sore thumb". FYI- the local auto paint suppler can not only mix up the paint for you but tint it (fade) as well to make it match better (if needed) and they can mix up a small batch and put it in an aerosol type spray can as well...................
Old Jun 17, 2022 | 04:37 PM
daveengelson
Thank you for U'r suggestions, yes, decided to go w/ the same 2 stage and found 1 of 2 local auto paint supplier's who actually mix the desired paint code requested. Intend picking up w/in next couple of days.
Greatly appreciated the input!!
Lamperr
Mar 15, 2022 07:24 PM
mcline
15
Aug 6, 2019 08:03 PM
CelticOne
Jun 23, 2018 05:19 AM
Blu Furd
1966 - 1977 Early Broncos
Dec 8, 2017 12:27 PM
greentruck72
Mar 4, 2015 08:04 AM
