66 F100 Rear End Leak
Well, it happened. I finally got paint on her (ESVE). With the engine out, parts all over the house, and finally at the point of stitching her back together. I noticed that the rear end leaking at the driveshaft and inner wheel. That's alright, it's another opportunity to take care of something before she's together and ready to ride. My question is, I believe that I have the ford 9", the plate says has "08". This should be a (Ford WDM-J-W-T)photo attached. I believe that I have the right seal for the hog's head to the axle housing and the seal in front of the flange. My concern is the grease coming from the inner wheel. I look on youtube and folks speak of the seal being between the bearing and the wheel. I look on the manual page 4-22 and it shows the seal on the other side of the retainer ring. If the seal that needs to be replaced is on the inside of the retainer ring, then I don't need to replace the bearings, right? Thanks in advance for the advice. I'll post photos of what she looks like all dressed up and ready to take out.
Looking at the pictures I believe the center section has been changed at some time. They only had a fill plug on the housing or in the center section not both. If that center has a fill plug in it, it likely isn't the original. If you pull it, you can count teeth and tell what ratio it is. Those axle seals can be difficult to remove if you don't have a slide hammer.
Thanks for the help, but I don't know if I'm holding my tongue the right way or what. Every one of the YouTube videos on the 9" rear end shows taking off the four bolts and it slides out like butter. Me, I pull and pull, denied. Reverse the brake drum, bang, bang, denied. Take the neanderthal approach and bang it with a stick and sit there like a monkey with a math problem. I don't what I'm doing wrong, but am willing to try anything prior to paying someone 100/hr to do the same thing I was trying.
The following 2 users liked this post by Crop Duster:
I watched my uncle one time work on a particularly stubborn axle and he hooked about at least a 10 foot long heavy chain to the lug bolts and then stood back and whipped the chain with a certain authority. Took a lot of tries still but it broke loose eventually. Looking back now I wonder if he had a slide hammer or not.
55RoundTwo
05-24-2020 02:30 PM
jrotten67
08-12-2019 08:42 AM
pburress
03-20-2012 11:03 PM
