Help getting tailgate back on
Old Jun 12, 2022 | 10:13 PM
Alpyandy's Avatar
Alpyandy
1st Gear
Bad enough that I’ve got the step so it’s super heavy, but the torsion rod, I guess, is stopping the left bushing on the gate from turning, which means getting the tailgate back on is almost impossible at the tailgate then has to be straight up and down and that’s all kinds of problematic. If that black piece with the insert would just turn a bit, this gate would be back on. Any ideas? Fixes?
Old Jun 13, 2022 | 05:50 AM
ToMang07's Avatar
ToMang07
It's really not that complicated. Line up and insert the tab on the left side, lift the gate to align the tab on the right and slide it down and on, attach cables.
Old Jun 13, 2022 | 06:59 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I haven't had my tailgate off yet, and I don't have the step....but will that slotted insert come out of your tailgate? If so, take it out, put it on the mount on the bed, then slide your tailgate back on it.
I recall one of my past trucks having a notched rubber insert like that, and that's what I did.
Old Jun 17, 2022 | 07:30 PM
saskowner's Avatar
saskowner
Ours has to be fairly high to go on but not close enough to vertical to cause any problems.
Old Jun 17, 2022 | 07:36 PM
scraprat's Avatar
scraprat
Top Answer: 5
That end just inserts, the other side has a slit that fits in the grove. I had mine off with the step a few weeks ago. Yes it's a little heavy and cumbersome but it will go back together with a little wiggling.
06pghescape
2009 - 2014 F150
Jun 9, 2021 05:28 AM
greyhound
1961 - 1963 F100 Unibody
Oct 15, 2019 09:44 PM
MIKE1646
2009 - 2014 F150
May 24, 2017 01:44 PM
1320stang
Jul 3, 2016 09:18 PM
Kurtboyd
Sep 13, 2015 05:02 AM
