76 4x4 brake issue
Old Jun 11, 2022 | 07:07 PM
Fordfarmer79's Avatar
Fordfarmer79
76 4x4 brake issue
Have a 76 f250 4x4 with the two piston front disc brakes. I have the brakes bled. The pedal will hold pressure while the brakes get bled, but as soon as you go to drive it, it will loose all pressure, engine off or on, but you can pump it up and get a very solid stiff pedal with brakes. No leaks. Front and rear soft hoses look rough, but aren't keeping pressure locked on the brakes. What do you guys think? I'm thinking it's the wrong master cylinder.
Old Jun 11, 2022 | 07:52 PM
tbear853's Avatar
tbear853
Sounds like an internal iiston leak issue in the master cylinder. The piston has sealing rings.
Old Jun 11, 2022 | 07:54 PM
76bigblue's Avatar
76bigblue
Trailering
Like the person before said it sounds like a bad master cylinder. If you have power brakes a leaky master can also kill a brake booster.
Fordfarmer79
Thanks, I have one on order. Also, there is another junction block down on the frame. I assume that is a proportioning valve? It has a sensor and wire on it..
Old Jun 11, 2022 | 08:01 PM
76bigblue's Avatar
76bigblue
Trailering
Yes that is the proportioning valve. When you bleed the brakes you are supposed to pull the pin on the front out to allow you to pressure bleed the front brakes.
Old Jun 11, 2022 | 08:05 PM
Fordfarmer79
Thank you, didn't know that.
Old Jun 11, 2022 | 08:56 PM
mark a.'s Avatar
mark a.
Are you sure the rear brakes are adjusted up tight ?
Old Jun 11, 2022 | 09:06 PM
Fordfarmer79
No, I haven't looked into them besides to look for leaks. I just got the truck and was getting good enough to move it around the yard when it's in the way.
Old Jun 22, 2022 | 06:41 PM
Fordfarmer79
Fixed my issue finally, thought it was a collapsed brake hose and it wasn't, it was indeed the master cylinder.
7.3dieselMike
Jul 30, 2014 03:00 PM
shameless
Oct 1, 2011 03:25 PM
byron74f100
Apr 20, 2010 02:25 PM
ttamwhit
Feb 26, 2009 06:48 PM
paqmaster
Oct 29, 2001 07:39 AM
