Adding Weight to Bed for Road Trip
https://shurtrax.com/full-size-picku...action-weight/
there is always the option of sand tubes as long as you strap them down well
Guess I'll join in... with more sandbagging.
Carrying along 400-500 lbs weight in the back of the pickup bed will indeed quite nicely work to provide a smoother ride.
The exact location where the weight is placed can have a noticeable effect on a number of related factors... from front end bounce over expansion joints, to steering traction, to the amplification effect of weight placement that would allow a lesser amount of weight to have the same effect toward increasing ride comfort.
A couple of years ago I took a bare F-550 chassis cab on a 700 mile trip to get a body mounted to it. The truck was optioned with the High Capacity Towing, Payload Plus, and Extra Heavy Service spring packages, with a 19,500 lbs GVWR, so driving the chassis bob tail without any bed or weight at all would have been a back breaking bouncy way to remove teeth.
I reasoned that if I placed 600 lbs as far as possible aft of axle, to the very end of the truck frame projecting behind the axle, that would have the same effect as placing 3 times that amount of weight over or slightly ahead of the rear axle.
So I strapped 600 lbs of sandbags to the end of the frame.
I built a highly visible "crash box" crib to carry the sand, so that shady lawyers would have a lot tougher time finding me negligent for their clients rear ending me by claiming that they couldn't see the end of the frame.
Be sure and strap any weight down. Otherwise, free weights will keep traveling at whatever highway speed you are driving at, even though you've hit the brakes.
This is another reason why sandbags are better than steel or bricks. Sandbags diffuse energy on impact, and the broad surface area is less likely to smash a window or dent your bed, even if your bed is covered with a tonneau or cap.
The 600 lbs weight aft of axle made a huge difference in ride quality for that trip.
An F-350 would not likely need as much weight, and weight placed near the tailgate will make more of an impact than weight centered directly over the rear axle.
Such an impact could have negative consequences if using too much weight, and driving over concrete freeways with expansion joints that happened to be spaced in time with the reaction frequency of the suspension at the speed you chose to travel.
I experienced this with a different F-550 while towing a heavy tongue weight tag trailer across Nevada. At a certain road speed, the front end of the truck bounced up and down uncontrollably. I traveled through 5 states on that trip, and only that one stretch of concrete freeway in NV gave me that problem. But it was problem. I could have solved it by redistributing the trailer load to have less tongue weight, but it was faster to slow down to below 45 mph instead, with flashers blinking, for the 40 more miles until the road surface normalized again.
Another advantage of sand is that it is sacrificial. It can be used for other purposes, given away, or lost. Sacks of gold would take up a lot less room in the bed, being almost twice the density of lead, but then you couldn't leave the gold behind on a trip if the extra weight proved to be inconvenient, in the way, or unnecessary. I double bagged my sandbags to keep the bags in perfect condition, and was able to "dump" all of the clean and unopened bags of sand at a local branch of the same nationwide chain home improvement store where I bought the sand, so there was no wasted material, and no wasted expense.
edit: I'm doubting my memory on exact count and weight. I know I put about 1500 pounds in the bed. If you can easily play with different weights go for it. I opted for sandbags to keep the load low and distributed. For testing, drop pallets with different amounts of weight and go for a test drive.
it was a one way trip for me, so I needed something that I could abandon and not cost a lot of money.
