"Engine" warning light briefly on
Old Jun 8, 2022 | 06:56 PM
15W-40's Avatar
15W-40
I had been driving 60 mph for about 45 minutes when I noticed my "ENGINE" light was on. It's the light down low on the left by the turn signal indicator. I'd never seen it on before, so I slowed down a bit and checked my gauges. I know they're notoriously inaccurate, but the coolant temp gauge was below the N on NORMAL and the oil pressure gauge was somewhere in the middle. No weird noises or performance issues.
Within seconds of me seeing it, the light turned off. I got home, checked the oil, and it is full. I'm maybe 2,000 miles into my oil change, so it's due soon. I checked the radiator temp with an infrared thermometer, and it read 190 F and the coolant is full.
Do you think I should check anything else or just keep driving it?
Old Jun 8, 2022 | 07:14 PM
Prototypemech's Avatar
Prototypemech
Kinda weird. IDI engines dont have computers so theres nothing to trigger that light. I didnt even know IDI's had a "Engine" light on the dash. On the 91-up, we have a dedicated annunciator panel that warns the driver about high fuel filter pressure, water in fuel, engine over temp, and a few other sensor. I dont think the '89s had anything like that. Perhaps the PO wired in the ENGINE light for some sensor.
Old Jun 8, 2022 | 11:49 PM
90Ford73's Avatar
90Ford73
My 90 has an engine icon, as well as a light that says engine or check engine iirc? I’m not entirely sure what triggers them, but they are there.
Old Jun 9, 2022 | 02:13 AM
Robfinger's Avatar
Robfinger
Red "engine" light is also known as "replace engine" light - it comes on when oil pressure is too low, coolant temp is too high, or at the age our trucks also when a wire for one of the aforementioned sensors has rubbed thru and is grounding on something.
The yellow "check engine" light does nothing on an IDI, it ain't connected to anything. On my own truck I've wired it to tell me when oil level is I think 3qts low (might be 2), using a sensor off a Mustang.
Old Jun 9, 2022 | 03:51 AM
tjc transport's Avatar
tjc transport
i ain't rite
as said, the only thing that will trigger that light is no oil pressure, high coolant temp, a bad sensor, or shorted out wire.
and you would know if you had no oil pressure or high coolant temp when running down the road by the way the truck was running...............or not running.
Old Jun 9, 2022 | 02:33 PM
Fixnstuff's Avatar
Fixnstuff
I agree with a wire occasionally grounding out.
Read this topic:
https://www.ford-trucks.com/forums/8...-question.html
Old Jun 10, 2022 | 09:11 AM
15W-40's Avatar
15W-40
Well, I'll add more to this saga today...
Yes, the truck has a red engine light that is tied to coolant temp and oil pressure. Thankfully the engine light hasn't come back since that one instance.
However, today, the battery light came on and stayed on while driving. The voltmeter on the dash read normal. I got to work and put a multimeter on the batteries while running and the battery light still on. Charging voltage is normal at 14.2V. There must be something on this truck that's haywire with the warning lights. Maybe there's a common wire for the engine and battery warnings?
Old Jun 10, 2022 | 05:01 PM
solanum's Avatar
solanum
Check your grounds, I've had similar things happen when the braided copper straps rot and fall off.
6.9IDIot
13
Apr 15, 2022 06:07 PM
scooter71
3.8 & 4.2L V6
63
Jul 25, 2018 11:27 PM
prestodave
1997 - 2003 F150
Aug 2, 2012 11:20 PM
clhart426
Jul 7, 2010 09:55 PM
forddriver17
Jun 9, 2009 10:17 PM
