dumby light ? while towing
Old Jul 6, 2010 | 08:48 PM
clhart426's Avatar
clhart426
78f150 4x4. has a 400.
-While towing my 18' ski boat today, down a 13mile stretch of 55mph highway, i got into town and started to slow down to 35, but slowly decrease in speed. when i was almost completely stopped(for the red light), my oil light came on. I quickly shifted to neutral to shut down my truck, and the light turned off. put back in drive and it starts to blink. but stays on until i give it some skinny pedal.
so onto my ?
-why would my oil light come on all of a sudden, and why does it turn off when i put it in neutral(its an auto trans).
-would engine temp. have anything to do with this? the temp gauge was almost to the far right H side.(and any ideas why it got so hot??)
Old Jul 6, 2010 | 09:06 PM
steponit's Avatar
steponit
Check the oil level
The light usually doesn't come on until 5 psi
Old Jul 6, 2010 | 09:16 PM
clhart426's Avatar
clhart426
checked. actually had just changed the oil right before i took off. checked the oil, full.
Old Jul 6, 2010 | 10:59 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The rpms increase in neutral versus in drive. So, for example, if you have less than 5 psi in drive, the light comes on. Shift to neutral and you get 7 psi, the light goes off.
There may or may not be a problem and the best thing to do is get a mechanical oil pressure gauge so you know EXACTLY what is going on.
Josh
Old Jul 6, 2010 | 11:54 PM
fmc400's Avatar
fmc400
MSEE
Well said. There's not much you can do to diagnose the problem until you can quantitatively establish the oil pressure's behavior.
Old Jul 7, 2010 | 09:46 PM
steponit's Avatar
steponit
There may be a piece of carbon or engine debris that is causing a pressure differential to the sending unit.
Old Jul 7, 2010 | 09:55 PM
clhart426's Avatar
clhart426
well i pulled it home this morning, before it got 95degrees. didnt have a high engine temp. or oil light come on. im thinking some of my engine heat problem may be comming from the fact that i dont have a fan shroud, but at 60mph the air should be blowing right through the radiator. which now means i have to pull my boat up to *******,mi with my pathfinder...i know, im heartbroken...
