IPR stuck
Old Jun 6, 2022 | 11:44 PM
Skyliercogswell's Avatar
Skyliercogswell
1st Gear
IPR stuck
HELP!
I'm trying to do the IPR on my 2006 6.0 and I've tried everything to get it off (pipe wrenches, breaker bars, ect) and it won't come loose, I've even put a 12" pipe on the end of my rachet and it still won't come loose.
Any suggestions?!?
Old Jun 7, 2022 | 08:37 AM
Hartwig's Avatar
Hartwig
Are you using the install tool?
Old Jun 7, 2022 | 10:13 AM
BLADE35's Avatar
BLADE35
impact gun
maybe heat the cover up some
Old Jun 7, 2022 | 02:00 PM
Rusty Axlerod's Avatar
Rusty Axlerod
3ft long extension resting against the driver side hood hinge, have ratchet outside of the fender. stand beside the truck and put a long pipe on the ratchet handle. Don’t use tools that have sentimental value, this is abuse but I’ve done it two times now.
Old Jun 8, 2022 | 07:34 AM
Striderwv's Avatar
Striderwv
PB Blaster overnight or longer soak.
Old Jun 8, 2022 | 09:30 AM
TooManyToys.'s Avatar
TooManyToys.
Man, I never realized they could be stuck that bad.
Old Jun 8, 2022 | 01:10 PM
BLADE35's Avatar
BLADE35
I didn't realize they could be stuck that bad either
Old Jun 8, 2022 | 02:07 PM
LCR's Avatar
LCR
Are you turning the correct direction? I'd think using all your force you'd have stripped something.
Old Jun 8, 2022 | 02:18 PM
55F-100's Avatar
55F-100
4wd Low
I broke the first socket I purchased for this it was a cheap version off of the internet, then I bought 2 from Advance auto encase it broke again I believe I used a Braker bar with a ball swivel joint. also removed ficm so I could get my delicate hands in the area. I won it gave up and came out made a loud pop sound thought I broke it again but did not. NOTE: all extensions socket ect should be of impact quality
Old Jun 8, 2022 | 03:27 PM
bismic's Avatar
bismic
Are all of you folks having to use breaker bars torquing the IPR upon installation?
If so, what torque value?
Old Jun 8, 2022 | 03:31 PM
55F-100's Avatar
55F-100
4wd Low
No not when installing just breaking them loose to remove them then use 3/8 ratchet to re-install.
Always remember Righty Tighty Lefty Loosey, unless it's around 1960 down Plymouth they had as I remember on the left side the lug nuts were left hand thread go figure?
Old Jun 8, 2022 | 04:34 PM
bismic's Avatar
bismic
I suggest a torque wrench to re-install then.
You can exceed 37 ft-lbs with a 3/8" ratchet.
Old Jun 8, 2022 | 08:21 PM
BLADE35's Avatar
BLADE35
I think someone other then dealer did an IPR before
This might need a new cover in ghe end
Old Jun 8, 2022 | 08:24 PM
bismic's Avatar
bismic
IPR for 05 + shown below (mounted on HPOP):
Old Jun 8, 2022 | 09:04 PM
BLADE35's Avatar
BLADE35
My bad I'm out of touch thanks for keeping an eye on me
