Sponsored by: Real Truck
93 vs 87 Octane
Old Jun 6, 2022 | 08:26 PM
kurthb's Avatar
kurthb
93 vs 87 Octane
I have always used 87 octane, but had this crazy theory that when towing heavy loads, it might actually make sense to use 93?
If there is a knock sensor on both banks, timing will be retarted if knock is detected, resulting in less power.
so....as "my" theory goes, if you can avoid knock by using 93, there won't be a chance of knock and always get the most available power.
This may be a reach, but towing a 8000# 5th wheel with a 5.4, every little but of power helps.
Thoughts?
Old Jun 7, 2022 | 05:13 PM
speedfreak78's Avatar
speedfreak78
Use whatever the owners manual says to use, that's what it's tuned to run on. You won't get any additional performance from higher octane, it's just gonna cost you more.
Old Jun 7, 2022 | 10:18 PM
kcducttaper's Avatar
kcducttaper
Doesn't make any difference other than draining your wallet.
Octane is just a combustion inhibitor, so higher octane tolerates higher temps before thermally combusting (due to compression) before the spark plug ignites it. The reason high horsepower engines use high octane is because they have much higher compression ratios than our 5.4's. Their air fuel mixture is compressed a lot more, which then heats up the mixture more than in our pickups before the spark plug fires. High octane prevents the high compression engines from igniting until the spark plug ignites the mixture at the correct time.
Old Jun 8, 2022 | 06:53 AM
OverheadCram's Avatar
OverheadCram
Thoughts?
Yes, plain and simple a higher octane gasoline is less volatile and will be less likely to pre detonate. You will have to check your cylinder temperatures in the engine while performing under the conditions you tow before going to a higher octane and seeing a benefit. If your cylinder temperatures are high enough that you are exceeding the 87 octane pre detonation point then going up in octane rating will help.
Ive tested my gasoline trucks for this many times. I tow 15-16k almost daily. Aside from really hot days 90+ degrees F I never noticed any conditions where I would benefit from higher octane. On the very hot days and the engine really working the knock sensors were quite active and switching to 89 octane did help. In the owners manual it does suggest running a higher octane while towing for this reason. At the same time though without verifying you actually need a higher octane all you are doing is guessing and paying more for fuel.
Old Jun 9, 2022 | 10:15 AM
acdii's Avatar
acdii
Unless you get a tune to take advantage of the higher Octane, you are just wasting money, with the few exceptions stated above. The Ecoboost engines are designed to take full advantage of higher octane fuels and it is recommended to use higher octane when towing, where it is "suggested" to use on the Superduty. With the price of Premium being higher than diesel, you will wish you had the power of the diesel for that price.
Old Jun 9, 2022 | 10:38 AM
redford's Avatar
redford
FTE Leadership Emeritus
You should consult your owners manual. For instance, the 2019 manual says you can use 87 octane with the 6.2L, or E85, but 91 octane should be used for "best overall vehicle and engine performance", then goes on to explain that the performance gain from premium fuel will be most noticeable in hot weather or while towing.
Old Jun 11, 2022 | 11:56 AM
acdii's Avatar
acdii
OP has a 5.4, which I believe would need a tune installed to be able to use the higher octane as the 5.4 doesn't have the hardware or programming to adjust to it's optimum use. A 5 Star tune should give him what he needs to get the most out of 93.
Dwscott27
2004 - 2008 F150
Dec 13, 2021 08:04 PM
bob1987f
2004 - 2008 F150
30
Dec 5, 2009 11:19 PM
CKSFORD
1997 - 2003 F150
Jul 17, 2007 07:02 AM
jimbn
Computer Chips & Tuners
Mar 12, 2006 01:13 PM
ford_prof
Sep 15, 2003 07:45 AM
