2000 e450 compression test results, not good
Old Jun 6, 2022 | 07:42 PM
LegalizeChey's Avatar
LegalizeChey
Hi everyone, got a compression test done on my bus today and well……. Not the results I was looking for….
I tested each cylinder twice. Letting the gauge puff about 5 times before I stopped cranking. The bus wouldn’t start already due to HPO issues and now I know where the compression stands….
results are as follows;
2) 300/325…… 1) 300…..
4) 325………… 3) 0……..
6) 100/125…… 5) 300….
8) 325………… 7) 0…….
How do I determine my next step? Leak down test? Put a little oil in the dead cylinders and retest? New motor?
This engine had broke down on me while driving on the freeway. I determined low ICP first, then dead head tested the HPOP and each cylinder head by itself. Found a bad injector which would leak internally. Resulting in 0 psi to the drivers side head.
I wanted to confirm engine health before diving into new injectors, but looks like I have bigger issues on my hands….. pretty demotivated, even more frustrated now….
Thanks for reading, please let me know what you think
-Chey
Old Jun 6, 2022 | 08:30 PM
PriusLover's Avatar
PriusLover
Did you check running compression? What tester are you using?
Have you run a blow by test (a proper one with a gauge)?
Leak down tests tend to be more reliable and tell you more than a compression test. If you can perform one it should provide a rather clear picture.
Old Jun 6, 2022 | 08:50 PM
Walleye Hunter's Avatar
Walleye Hunter
That is ugly. Any idea why you got two gooseggs? Will a small diameter borescope fit through your glow plug holes? It might be helpful to you if you could take a look inside.
Old Jun 6, 2022 | 11:26 PM
LegalizeChey
I did not check running compression before it broke down, I can’t do it now because it will not start…
I have not done a proper blow by test either…
I believe most would agree that a leak down test is the last thing you would do before determining pulling the motor or opening it up, no?
Not a clue, I do need a new scope for work so that’s convenient….
Old Jun 7, 2022 | 07:22 AM
FordTruckNoob's Avatar
FordTruckNoob
Ouch. The only time I had 0 compression was when I blew a hole in my piston. The others have got you covered. Run a leakdown on 3 and 7 to see what's up.
For the borescope, I can tell you the glowplug hole necks down from what you can see at the top of the cylinder head. My borescope with a 5mm head will not go all the way through into the cylinder.
Old Jun 7, 2022 | 09:21 AM
Walleye Hunter
Well...that bites. I have an engine out there with the injectors out of it and my scope fits through those so there's an alternative. I also don't know what diameter my scope it, it's narrower than the cheap one I bought a few years ago.
Old Jun 7, 2022 | 09:23 AM
LegalizeChey
Looking into leakdown procedure right now… I hope no holes or bad cylinder walls! Obviously something is wrong otherwise there would be compression
Old Jun 7, 2022 | 01:11 PM
bwguardian's Avatar
bwguardian
Have you looked at the valve train operation on those 2 supposed dead cylinders while cranking?
Old Jun 7, 2022 | 03:44 PM
LegalizeChey
not with exquisite detail, but the valves are operating
gregorian
26
Mar 26, 2018 12:53 PM
minnesota-clint
Jan 25, 2015 01:52 PM
Meanstreak97
Aug 1, 2014 09:11 PM
truck crazy man
17
Feb 6, 2014 07:50 PM
1977ford250
Nov 6, 2009 10:14 PM
