Have you done a wet/dry compression test?
Put a little oil in the cylinder and see if your compression goes up. If it does, you have issues with your rings. If it doesn't, you have issues with your valves. Valves would be the easier of the two options, as it may simply be that the valve isn't closing.
But, there's no way to know without first finding why it lost compression.
