2g to 3g conversion woes
I own a 94 F250 with the 7.5L 460. My headache all started a few months ago with a weird starter issue, basically it would start fine cold but would act like i had a dead battery when warm. As I was poking around I thought I would check the battery to block ground. I couldn't see where it grounded because of the damn smog pump so I climbed under to see if I could feel where it went. I found the cable with my hand and it snapped. All I saw was exposed and very corroded copper and all that was left were hard vulcanized chunks of rubber that was the wire shielding. At this point I was determined to do the following:
- Replace the battery terminals and cables.
- Replace the starter relay
- Replace the Alternator
There's no external regulator on a 94 so I wired it according to powermasters instructions:
- Cut off the stock ASI connector.
- Wire green/red to green/red on the new alt connector making sure to put the provided 500ohm resister inline.
- Make sure the yellow wire on the alt is connected to battery positive (it came out of the box looped back to the positive battery connection at the alternator.)
- Wire the positive on the alt to the positive side of the battery
- Wire the negative to a good ground.
At this point the only wire I haven't connected is the yellow wire and this weekend I'm planning on tying that in to the + terminal on the alt.
TL;DR
My questions is this, has anyone done a 2g to 3g upgrade on their truck? Did it work great the first time or did you run into issues? Assuming you have everything wired up correctly, what are common reasons for these 3g alternators to not work. I'm basically just looking for anything I might not have tried. Any avenue of possible closure on this project of mine. Thank you.
TL;DR
call Powermaster tech support
The positive if I dont recall correctly doesnt wire to the battery but to the starter solenoid (somoen tell me im wrong if im wrong)
Your "yellow" wire is wired to your alternator, is that the one thats separate from the plug(single wire) because if so THAT IS THE CORRECT PLACE FOR IT TO WIRE
Wire the negative? What negative? Your alternator case grounds ot your (engine brackets>engine>ground>battery ground path)
you played a lot with your wiring.. at no point I dont see where you wired your cluster telltale which excites your alternator to the alternator
Resistance battery to alternator is Nothing, that reading is meaningless. voltage drop while its running is soemthing but you dont have an alternator putting out juice yet.
Wait, you said you wired the yellow. now its unwired?!
Stator wire is connected to the truck harness?
You have motorcraft*, so the * is applicable
But a new regulator connector came with the new alternator, so that worked out?
Battery, or battery side of the starter relay, or the BAT terminal of the alternator, all work well for most.
That's the BAT terminal, correct? I assume yes, but wanted to be sure.
Where did you connect the ground? It supposedly grounds well through the case to the engine, but I've always added a ground as well. Just because...
The White w/black stator wire goes only one place on a 3G. That's the small terminal in the side of the alternator near the regulator connector. Without that, it won't charge.
Even if it's supposedly connected there, verify because I've seen them slipped to the side of the actual contact point inside and not actually making a good connection. And it's hidden by the plastic end connector on the original plug, but yours might not have that anymore?
However the missing White w/black stator wire is guaranteed (in most cases) to leave you without a working alternator.
I say "in most cases" because I once had a 3G work perfectly well without it. No idea how that worked out, but it did. Maybe it was a 4G in disguise?
Any chance we can see some pics of your setup?
Thanks
paul
