I did pop the cap off last night and looked through it and inspected the FSS it all looked good. I didn't see debris or anything bad, and the FSS was in good shape. As for measuring pressure at the IJ inlet factory spec is 1psi at 3000 rpm. It definitely has at least 1 psi of pressure. I've cranked on it for 5-10 mins a day every day the last week. Would that not be enough to get air out of the system.
Edit: I read on another thread that the pumps can get clogged. Should I trying running seafoam or atf through it? I think I might try to empty the pump, leave the return line off and make sure fuel is getting in through the center inlet. Does that sound like a good idea?
Have you cranked while a fuel line was cracked at an injector...allowing fuel to escape at the injector?
Yes, the first couple days all 8 we're cracked. That last few days only the 6 easy ones to get to. I even tried it with one all the way off yesterday and I didn't feel any pressure on the line.
I got the truck running, it turned out the internals of the injection pump where bad. I got a remanufactured unit and it instantly bleed the air out. There are still many fires to put out though, one being the heater core. What size treads are the barb fittings for the heater hoses? I need to get a new one that goes on the water pump. The big long one.
My temp gauge never gets past the beginning of O in normal, is that normal (I live in north Eastern Kansas average daily temp right now is 35-45 degrees). The heater is only every warm not hot, and I put in a new heater core. I used a factory motorcraft 190 t-stat is there a chance it's an issue? Should I go for a higher temp stat?
My 86 with 331K miles usually points to the R on normal.
The gauges on these trucks are not real accurate.
You could have some debris in the Blower (Mice nest) or
clogging the fins on the Heater core.
Also all the air goes through the AC Evaporator and the fins
on it can be clogged also.
Your Blend Air door inside the heat box may not be working,
and letting in cold air.
Goat
I have a temp gun, but it's decided to miss place itself when I need it. Once it's found I'll check temperatures. I was able to get the heater working though, the core was leaking so I replaced it and cleaned out the box. A large chunk of cardboard and some wire crimps where holding the door open. It still leaking some cold air in, but I believe that's just age on the seal and I'm not sure how to fix that issue. Otherwise works good and will run my out of the cab after 15-20 minutes of driving.
I've never disassembled the airbox on my Bullnose truck, but you may be able to replace the aging seals with generic adhesive weatherstripping you can get at the hardware store.
I've got major issues.
the truck is loosing prime somehow, it runs then dies then it cranks forever before starting. Now today it started surging then would go back to normal driving. Then it devolved a dead miss on at least one cylinder, and started shaking violently. What the heck is wrong it's got a remanufactured injection pump on it? I don't think it's out of fuel the guage is still at 1/4 tank.
If your truck has the setup where the fuel line in the tank has a plastic "foot" on it, the foot can eventually fall off, causing you to run out of fuel with the tank 1/4 full.
Alright I put 5 gallons in the truck. Runs like a top, zero issues. I'm guessing that foot in the tank is broken off, so for now on I'm keeping the truck above 1/4 tank. Happy it seems to have been a simple fix.
