I'm stumped front end problems
Old Jun 6, 2022 | 06:37 PM
Willsprojects's Avatar
Willsprojects
So mounted the track bar behind the axle and it definitely fixed th problem so I shortened the ad track bar from 29 in bolt hole to bolt hole centers to 22 1/2 in preheated and welded it back together and then made some brackets out of 1/8 in plate steel and used grade 8 hardware it's a little crude but it works
Old Jun 7, 2022 | 03:25 PM
Robfinger's Avatar
Robfinger
That's more or less how the factory trac bar if an F350 of your model year would sit as well. 1/8" is hella thin tho I think, on the axle side at least as you're only running single-shear there on that big bolt. Beef it up a bit, and you'll probably never mess with it again till you do your RSK install.
Old Jun 7, 2022 | 05:34 PM
Willsprojects
I'll be correcting that soon just wanted to make sure It would work before i bought another 3/4 in drill bit
Old Jun 8, 2022 | 04:12 PM
Robfinger's Avatar
Robfinger
Step bits!!! And lots of cutting oil. Anything larger than 1/2" and I don't touch "proper" drill bit and do it with a step bit instead - those don't tend to stick and grab like normal ones do, and you can make some ridiculous holes with just a battery powered drill.
Old Jun 8, 2022 | 05:53 PM
Willsprojects
I was using a Milwaukee cobalt step bit and while I was working I knocked my drill off the work bench onto the concrete floor with that bit in it so had to buy another got it fixed though lol used work at a machine shop the only time you use a proper drill that big is in a lathe or end mill
‘97CCSB
Sep 8, 2021 01:59 PM
Surfguy66
Jul 4, 2021 10:44 AM
Cole Eakle
1997 - 2003 F150
Dec 19, 2018 02:44 PM
Pwnm30rdi3
May 15, 2012 06:29 PM
joshn569
May 17, 2009 07:43 PM
