Steering stabilizer help
Old Jun 5, 2022 | 09:13 AM
Mikelikesit's Avatar
Mikelikesit
In my post above the one on the lower right is the tool I used.
If your using the fork. What about hammering it in tight.... Then hitting the threaded rod where you cut it off with a punch? While its under stress from the fork....A little heat on the rod too.
I dont like beating things. Thats why I prefer the puller.
Old Jun 5, 2022 | 05:26 PM
Fireferg73's Avatar
Fireferg73
Cut off the stabilizer and then drill the stud out. That’s what I had to do on my old one.
Added some anti-seize when I installed my new one.
Old Jun 5, 2022 | 05:37 PM
Fireferg73's Avatar
Fireferg73
And if yours is anything like mine, no amount of heat, penetrating oil or banging is going to work. Almost like the two types of metals fused inside the tapered hole. The stud is tapered and the hole is somewhat tapered. I used an air drill to give me the best space advantage. Stepped up the bit size and the remnants of the stud eventually fell right out. Good luck.
thatsrealnice
Sep 21, 2021 09:56 PM
60'_f100
46
Mar 23, 2015 09:36 PM
cje07
1978 - 1996 Big Bronco
Nov 15, 2008 02:30 PM
teds74ford
Offroad & 4x4
24
Jun 17, 2008 06:19 AM
inlandsurf
Apr 30, 2008 08:45 PM
