Sponsored by: Real Truck
fuel pump shuts off
Old Jun 1, 2022 | 04:07 PM
beanie110's Avatar
beanie110
4th Gear
fuel pump shuts off
Have a 2008 F250 V10 gas. The fuel pump will work when you first start the truck up and after about 5 minutes it turns off. We have replaced the battery, replaced the fuel pump, fuel driver module, replaced the fuel rail sensor and still having the issue. The system has a good ground. We even reset the interia switch. We are now at a lost on what to try next. If you disconnect the driver module when the pump has turned off and reconnect it, the pump will turn back on but not for as long as when you turn the key off and back on.
Old Jun 1, 2022 | 05:27 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is the pump quitting by itself or is it being commanded to turn off?
Old Jun 1, 2022 | 05:32 PM
beanie110's Avatar
beanie110
4th Gear
So, as far as we can tell turning off itself. Had a voltmeter hooked up and you see when the volts drop it shuts off
Old Jun 1, 2022 | 05:34 PM
projectSHO89's Avatar
projectSHO89
If the power is dropping, then the pump is not turning itself off. Power to it is being removed "upstream" from wherever you measured it (not specified).
Old Jun 1, 2022 | 05:41 PM
beanie110's Avatar
beanie110
4th Gear
We measured from the connector at the fuel pump. Following the troubleshooting to see if it is from the positive or the negative. But what would shut the power off from it.
Old Jun 1, 2022 | 05:55 PM
beanie110's Avatar
beanie110
4th Gear
Also the ground voltage goes up and then the pump shuts off
Old Jun 1, 2022 | 06:46 PM
99f350sd's Avatar
99f350sd
Don't know exactly how it is supposed to run. Its different from mine.. The computer runs the module to deliver fuel as needed..as far as I know..
Old Jun 1, 2022 | 06:52 PM
projectSHO89
That doesn't make any sense.....
Old Jun 1, 2022 | 09:06 PM
99f350sd's Avatar
99f350sd
Ground? What do you mean ground voltage?
There should be a ground on the frame back there somewhere. Do you have wiring drawings?
Old Jun 2, 2022 | 07:41 AM
redford's Avatar
redford
Is your fuel tank/fuel pump chassis ground clean and tight?
Old Jun 2, 2022 | 10:41 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
With all that stuff you replaced, did you test or replace the fuel pump relay?
Dean Matice
Modular V10 (6.8l)
Apr 28, 2021 02:13 PM
myonlytruck05
Mar 2, 2013 02:29 PM
ghitierman
Apr 13, 2007 07:04 PM
htcsusn
Jan 3, 2007 06:57 AM
FreeFall
17
Dec 22, 2006 10:07 PM
