How many miles before Cold side intercooler problems?
Old Jun 1, 2022 | 10:23 AM
Flitastic's Avatar
Flitastic
Just trying to plan ahead here. About how many miles are average for the cold side intercooler pipe to fail? Was thinking might be a good idea to have it replaced before it can fail. I have a 2019 with 30K. THanks!
Old Jun 1, 2022 | 10:47 AM
AMEC Electric LLC's Avatar
AMEC Electric LLC
My 19 F350 at 64,000
Old Jun 1, 2022 | 12:38 PM
Pugga's Avatar
Pugga
No real science to it. It will work until it doesn't.
Old Jun 1, 2022 | 02:57 PM
AMEC Electric LLC
This is the second time this happened to me on a 6.7. First, on my 2011, then the 2019. I would have gone aftermarket had I realized Ford never upgraded.
Old Jun 1, 2022 | 03:29 PM
Flitastic's Avatar
Flitastic
Thats why I was asking. I'm at 30K and would rather not have a failure. I'm probably ok for a while but wondering if you put an aftermarket one on there if it would void your engine warranty?
Old Jun 1, 2022 | 03:37 PM
4wd6.7L's Avatar
4wd6.7L
No, it would not void your engine warranty. The CAC pipe would have to be the cause of whatever engine failure it might have.
Old Jun 1, 2022 | 03:38 PM
1olddogtwo's Avatar
1olddogtwo
My intercooler (not pipe) failed at 120K, now at 270 with no other intake problems
Old Jun 1, 2022 | 03:40 PM
4wd6.7L's Avatar
4wd6.7L
Was coolant getting inside?
Old Jun 1, 2022 | 06:41 PM
chadstickpoindexter's Avatar
chadstickpoindexter
I plan to do a decent amount of towing (although, it's a fairly small camper) so I went ahead and swapped mine for the S&B CAC pipe at around 3700 miles. The S&B pipe is much nicer and will obviously stand up to much more abuse than the stock CAC pipe. However, saying that, I do keep the stock pipe in the toolbox in the bed of the truck... just in case! I can't say that it was necessary, but I do feel better about it...
Old Jun 1, 2022 | 11:06 PM
honda250xtitan's Avatar
honda250xtitan
SPE has a cheap OEM style one thats upgraded materials. or they have the nicer version. the cheap one is kinda hard to find on their site.
I went 60k ish until mine split. to be fair, i dont know when it split, i thought it was a different issue lol.
Old Jun 1, 2022 | 11:07 PM
honda250xtitan
did you go oem or the mishimoto? the Mishimoto shows solid gains, its very tempting but pricey.
Old Jun 2, 2022 | 06:16 AM
deveroutdoors's Avatar
deveroutdoors
I think mine made it to around 130K before the hose started cracking. I replaced it with an aluminum kit from Amazon and it's holding together fine 20K later.
Old Jun 2, 2022 | 07:19 AM
1olddogtwo's Avatar
1olddogtwo
No, it was blowing it out of the secondary cooling system.
the first time it did it, motor derated. No codes or anything. Was towing about 40K. At the time didn't catch it has blown the coolant out. Well waiting for a another truck to arrive, motor cooled down. With no trailer, the truck drove fine back to the shop. Dropped at Ford, they pressure tested the system and it held. They assumed it was a bad temperature sensor may just replaced it.
Week later, the coolant reservoir was empty, it would only blow under heavy load. Put a used one in at a considerably less cost. It was 1400 used vs something like 3600 new
metroplexchl
Oct 5, 2020 04:16 AM
zekes66
Jan 16, 2018 07:36 PM
kjd212
May 13, 2016 09:12 AM
DSG07STX
2004 - 2008 F150
Feb 4, 2007 02:07 PM
bart6180
Jan 28, 2007 04:18 PM
