Sirius XM Drop Outs
Old May 31, 2022 | 11:44 AM
SMarquez's Avatar
SMarquez
Sirius XM Drop Outs
I have intermittent drop out with Sirius XM. I shut down for whatever reason, different lengths of time and when I start back up I my Sirius is dead. It shows up in Sources but does not respond to inputs. It may come back after one key cycle, it may take 3 or 4 or maybe if it sits over night. I'm leaning toward it being a B&O issue since I don't have that problem in my other vehicles with aftermarket stereos and SXM.
Anybody else seeing this problem?
Old May 31, 2022 | 04:13 PM
Split rims's Avatar
Split rims
Disconnect the battery/ies for a half hour.
Old Jun 6, 2022 | 04:16 PM
GABAR's Avatar
GABAR
Don’t disconnect the battery for a half an hour.
Juts go into the SYNC settings and do a Master Reset.
This does the same as a battery disconnect without the hassle.
If the problem continues, make sure that your SYNC system is up to date by going to the Owner.Ford.com website to check via your VIN#.
If there are no updates available, you might have an APIM issue so a trip to your dealer to confirm this will be required.
Old Jun 6, 2022 | 05:19 PM
RidgwaySD's Avatar
RidgwaySD
I have the opposite problem. I have let it expire and now on every restart they are trying to sell me that garbage. I will have to re-up my Forscan acct so I can remove it permanently and completely. There are way better options than SXM
2012 F250 6.2
May 6, 2018 01:07 PM
cstoc235
2009 - 2014 F150
Jan 31, 2016 01:23 PM
pilot10
Escape & Escape Hybrid
Sep 1, 2006 04:45 PM
electricsheep
Electrical Systems/Wiring
Dec 15, 2004 09:14 AM
gofastbig3
1997 - 2003 F150
Nov 9, 2000 12:27 PM
