Carpet installation
Old Jun 5, 2022 | 02:02 AM
1949f1's Avatar
1949f1
OK, Thanks'. I also have the eliminator ( I think that's what it's called ) Throttle pedal with the thick carpet spacer. I will try my best to go by your instructions. Thanks' again
Old Jun 28, 2022 | 06:49 AM
Vegastype's Avatar
Vegastype
@F100supercrew Great information! I have the same shifter, when you measured to cut the hole did you take the measurements from the mounting bracket or the shifter itself? Does it matter what gear it it is? When you put the boot on did you unscrew the **** to get the boot on the shifter?
@1949f1 Let us know how you make out or made out if you have done this already I will be moving on to interior shortly on my 49 as well. All suggestions or tips are welcome.
Old Jun 28, 2022 | 07:11 AM
F100supercrew's Avatar
F100supercrew
carpet
Keep it in park roll carpet out and mark shift stick or measure to stick cut round hole like in picture------do you have round boot or rectangle boot---
Take shift **** off ( DO NOT MOVE LOCK NUT ) -- count turns when taking off put boot on then ready to put **** back on
Old Jun 28, 2022 | 07:22 AM
Vegastype's Avatar
Vegastype
I have the round boot.
Old Jun 28, 2022 | 07:39 AM
F100supercrew
carpet
OK then do not make the round hole to large -- do like it is in the picture can always make it bigger --after all installed and **** back on see how the shift works smooth and button works correct--
Old Jun 28, 2022 | 08:57 AM
1949f1's Avatar
1949f1
I used a old bed sheet for a pattern on my 49. worked out pretty good.
Old Jun 28, 2022 | 08:59 AM
1949f1's Avatar
1949f1
Also the little gap above the column i used 2 way tape to hold a piece in. you can't tell either. I just don't have a picture
Old Jun 28, 2022 | 12:14 PM
Pappys53's Avatar
Pappys53
Originally Posted by Pappys53
what do you do for heat? How wide is the air unit?
that I s abs. I am using carpet since that is what came in the LMC kit. I picked up a sheet of panel board to use in the corners
Bobby Detecting
Oct 20, 2021 12:40 PM
Old Guy F-250
15
Jul 26, 2021 03:47 PM
MightyThor
Sep 24, 2019 09:07 AM
dorkpunch
Oct 18, 2009 07:30 PM
