Not sure about your volts, but you can use a piece of wood/old broom handle (cut to the correct length) to hold the brake pedal down. Wedge it between the pedal and the front bottom edge of the seat. Or use a cement block/paver to hold it. Got a junk mirror, put it on the shop back wall to see if the lights are working.
How many volts should I be seeing in the rear light wiring with the headlights turned on?
I checked all 4 wires with a multimeter tool. The brown wire has 1.2v with headlights on. Not sure if this is normal or not.
I'll need to check brakes when I have a helper.
You should be ssing nominal battery voltage on all your light wires. 1.2V indicates a bad wire (ie-connector or corrosion)
Thanks. That's what I was thinking. I'll start at the fuse box and work my way to the back of the car.
I may need to run all new wires from the fuse box to the rear. The original look seems to be intact/wrapped but I guess it doesn't mean there isn't an area of corrosion somewhere.
ok. had a bit of time to cont investigating my lack of rear lights. I tried using a multimeter tool to measure voltage across the individual fuse terminals. I'm not sure if I'm using the tool correctly, I have it set to volts, and on DC but I'm not getting consistent reads. measuring across the battery terminals, I'm getting around 12.5v. at times, when I try measuring across the terminals for the rear light fuse, I see 11.6-11.7v but it's not consistent. I grabbed one of the cheapo voltage checkers that lights up from Amazon and am getting a consistent 11.6-7v across all the fuses w/ key on, before and after the fuses.
This tells me that fuse box is at least working, and I need to learn how to use the multimeter tool a bit better.
When i touch the rear harness wires, I'm not getting anything close to 11-12v, mostly some low voltage measure in mV. Should I be getting the 11.6v that I'm seeing from the fuse box? I assume that I should be.
I guess I'll start cutting into the harness and see if there's a short circuit, any crumbling wire insulation, etc.
At least I know the problem is somewhere in the wiring between the fuse box and the rear of the truck, right?
Yes, it should be nearly the same as you are getting at the fuse box. To be honest, the simplest way to fix this might be to run a new wire from the brake pedal to back. At the very least, you can put a plug connector on at the light, and run a new wire, plug it in and see if it works. If it doesn't, you can plug it back into the original harness.
