Sponsored by: Real Truck
01 Excursion- multiple issues, HVAC, Cruise, 4wd
Old May 25, 2022 | 10:12 AM
hertfordnc's Avatar
hertfordnc
I bought this truck in 2020 with 154,000 miles - runs great. Had just two issues. The 4X4 auto does not work, i have to manually lock the hubs. And, under a heavy load the AC will go from dash vent to defrost vent. This would only occur when towing a trailer but recently it got worse, now it happens with any serious acceleration.
Also, a couple months ago the cruise control stopped working.
The cruise light does not come on when i select or set cruise control.
As all these systems are vacuum controlled I'm wondering if there might be a common link?
I'm getting ready to hand it over to a mechanic but if anyone has any suggestions for what to check first I'd be grateful.
Old May 25, 2022 | 01:19 PM
Mike1's Avatar
Mike1
Sounds like you have a vacuum leak, usually where the lines plug into the wheel area or the seals behind the wheel hubs are bad.
Old May 25, 2022 | 01:24 PM
projectSHO89's Avatar
projectSHO89
Vacuum leak. Check the PVH solenoid, they tend to get cracked cases and leak.
Could be any of a number a things except vacuum. Speed control is all electrical.
What engine is the truck equipped with? Circuits are different...
Sharps
May 6, 2018 10:44 AM
pkwest
Sep 17, 2007 10:12 AM
76fordman
Mar 11, 2002 08:35 AM
