Sponsored by: Kumho
Parking Brake Spring
Old May 20, 2022 | 04:24 PM
WV350's Avatar
WV350
1st Gear
Good afternoon all,
I have a 1997 F350 133" WB 4x4 with 7.5L and 4R100 Tranny. I am working on the rear drum brakes and have run across a small thing that I am not sure of. There is a spring located between the outside of the parking brake lever and the inside of the flat washer for the Parking brake lever bolt. I am trying to find a good drawing of this and the one that I have found shows the spring inside of the parking brake lever instead of outside. I am trying to determine which is correct and also, where I can get one of these springs so the part number will help if it is on the drawing.
I have attached a pic with a red arrow pointing to the spring that I am referencing.
Any help would be appreciated.
Steves55
Jan 12, 2021 05:28 PM
oldracerjones
Jun 25, 2019 07:59 AM
Padilla Shore
1947 and Older Ford Trucks
Dec 17, 2017 04:05 PM
newguy399
Oct 16, 2016 10:16 PM
glenn-rod
Jun 2, 2006 03:35 PM
