Sponsored by: Real Truck
millright3
Old May 20, 2022 | 08:51 AM
millright3's Avatar
millright3
3rd Gear
millright3
My 2005 F250 King Ranch with digital ac controller has no power on the controller. I have checked, and tested, all fuses and relays to no avail. I switched headlight switch on and off a few times in the past and restored power to it. This time that did not help. I also disconnected both batteries for an hour and that did not help either. Any suggestions would be gratefully appreciated
Old May 20, 2022 | 09:02 AM
GGALLIN1776's Avatar
GGALLIN1776
Sounds like you might want to pull the GEM behind the fuse box & make sure there's no moisture/damage in it.
When voodoo like tricks make unrelated electrical components start to work, that's generally your culprit.
Old May 22, 2022 | 11:32 AM
millright3's Avatar
millright3
3rd Gear
millright3
I cannot find the BCM (GEM ) on my 2005 Ford F250 King Ranch SD 4x4 6.0 diesel. Anyone out there have any clue as to it's location. I looked behind the fuse panel and did not see anything that looked like it.
Old May 22, 2022 | 09:15 PM
GGALLIN1776
It's bolted to the rear of the interior fuse panel.
CWalters0806
Aug 11, 2015 02:54 AM
JimGeorge0723
Electrical Systems/Wiring
Jul 14, 2014 09:36 AM
Bobert
Sep 1, 2008 09:17 PM
lexasgs400
Oct 10, 2007 01:38 PM
MikeBroncoII
Bronco II
Oct 20, 2004 08:13 PM
