1996 F250 headlight troubles
I have a 96 F250 and my headlights have decided they want to go out. They were fine just the other day but now they wont turn on. I have an HID kit so I thought the HID's were the problem but then I put my my old headlights back in and I only got high beams so now I know that it's something with the truck itself. I did some looking and people with similar problems were saying that its the dimmer. And I also checked to see if i was getting power to the lights and only the high beam was getting power so i thought it had to be the dimmer. Well i just so happened to have an extra laying around so i hooked it up but got nothing, it made no difference. So now i'm sorta lost. My HID's dont work at all and my halogens only work on high beam. Any help is appreciated!
You got high beam but no low beam (both high and low beam use same power circuit and ground)
Strongly suggests your beam select switch as the problem, part of the multifunction switch (you know as in the turn signal lever sticks out of it).
Got power to the beam switch at the red-yel wire? (you must have or no high beam), coming out of the beam switch power to low beam via red-black wire. Power to high beam via lt grn-blk wire.
If no power at the red-blk wire when you cycle beam switch the lever to low beam position? the switch itself is toast.
I'm a little confused on what you have checked and what is actually working. In post #1 you said the halogen lights work on high beam but then in post # 3 you said that you get the high beam indicator in the dash but the headlights don't work. If you already replaced the multifunction (post #1) with a good part I'd think you have a bad headlight switch.
Power comes from the headlight switch over to the multifunction (turn signal/dimmer) switch. Do you have power from the headlight switch into the multifunction switch? Without taking my '94 apart to see what color my wire is, my Haynes manual shows it as a red/yellow wire providing power to the dimmer.
Pretty much what Danr1 said and what I mentioned a long time ago.
according to my schematic the wires come out of the multifunction switch and go straight to the headlight bulb(s). Time to start chasing the wire harness looking for broken wires...
EDIT: where does the HID kit splice into the harness? Is there power from both low and high beam going into it?
SaltedTrucker
07-12-2015 11:04 AM
torquemeister
13
01-30-2004 11:59 AM
