Dave, thanks for the info. I will try those ideas and see if I can find a pan or make one. As far as gas goes you are the third person to mention that. I will try something else next time. I had been using premium. Thx!
Not the grade of gas, regular / mid / high test, but a different brand like from Shell to AMCO or around here from say Speedway to Sheets.
Different brands have different blends and sometimes cars & trucks dont like a brand and switching helps.
Also I cant see spending the extra money for premium so you may want to try regular from where you are getting gas now to see if that helps.
I would not switch brands & regular because if it now starts faster you made 2 changes at once and you dont know what helped.
Also if it got worst for the same reason, 2 changes at once not good.
Dave ----
