HEI probelms
Old May 19, 2022 | 08:38 AM
gogoat's Avatar
gogoat
HEI probelms
I have an aftermarket GM copycat HEI distributor in my 302. Seems like it goes thru a couple modules every year. I drive accross town and no start. change module and then starts and maybe goes 3-6 months. Is there a good brand out there I should be using? The original one lasted 4-5 years then this ongoing problem. Or should I look at the coil or replacing distributor. I added an extra ground into the base of the distributor. I cleaned and reinstalled all ground straps also. Thanks for any input.
Old May 19, 2022 | 08:59 AM
EBEAR's Avatar
EBEAR
Is the small ground installed from the top of the coil ?
Old May 19, 2022 | 11:16 AM
F100supercrew's Avatar
F100supercrew
HEI
In my Ford HEI's I always remove the CHINA ones that come with the unit and I go to my local NAPA and get one made in USA and always have great luck with them it is a GREAT distributor to use with the USA made part
Old May 19, 2022 | 11:17 AM
F100supercrew
HEI
Old May 19, 2022 | 12:54 PM
Old F1's Avatar
Old F1
I don't think even the main auto parts stores modules are made in the USA.
I had a heck of a time with the aftermarket distributor in my 460 F1 burning out modules (all makes) until I realized that it was the hot soak after shut down that was causing the problem.
The trapped hot air could not get out until I louvered the hood and left the cooling fan run for a few minutes after shut down.
BKSMN
31
Jul 12, 2019 01:24 PM
Knockonwood
May 21, 2019 03:51 PM
Ghostka78
May 1, 2013 09:24 PM
amsuco
Dec 4, 2008 08:45 PM
