Weak A/C Airflow
Old May 18, 2022 | 03:05 PM
srsbjohnson's Avatar
srsbjohnson
Weak A/C Airflow
Ok, I have a 1995 Bronco that has weak airflow. I have completely had the dash out and replaced the heater core and checked for blockage. All is clear and everything is working fine. The motor has all the settings from low to high but it is still weak. What do I need to check next?
Thanks
Old May 18, 2022 | 06:21 PM
Scndsin's Avatar
Scndsin
Blower motor resistor.
If you haven't been down there & pulled it out & cleaned the crap that settles in there, that can cause it to get hot & slow things down.
Old May 18, 2022 | 08:50 PM
srsbjohnson
I chcked that when I had it apart. I did pull it out today and checked voltage and it only has 11.36 volts. Does anyone have a wiring diagram?
Old May 18, 2022 | 09:56 PM
Blurry94's Avatar
Blurry94
Have you checked to see if the Evaporator is clogged?
54Hydro
Nov 8, 2015 10:16 AM
Mr. Green Jeans
Feb 3, 2012 09:12 PM
gingerbreadmaniac
Oct 19, 2009 09:38 PM
hemiyota
May 28, 2006 12:51 AM
