What is this wire?
The white/ red on the bottom of the pic. The bigger white/red is the oil pressure sending unit.
You have the oil and alt gauges. One white/red wire to the oil sender for the gauge and one wire to the switch for the light. The gauge wire should have 5.5 volts the switch wire 12 volts.
Did you ever determine if your frame stamp matched the warranty plate you have?
I could not pull the Vin off the frame but I think your observation is correct. Is what it is, it's titled in my name now...
I did get her running, purrs like a kitten, other than it needs exhaust. Cleaned out the gas tank yesterday, need to put that back in. Current gas tank is a jug sitting on the floor with a fuel line dropped into it off the pump... Then look into brakes. After that I'll take her for a spin!! First time she will be on the road in over 15 years!!!
