Interior swap
Old May 17, 2022 | 01:06 AM
triorez25's Avatar
triorez25
Interior swap
So this is out of left field but could i put a 87-91 interior in my 84? I like their dash but the exterior is kinda meh
Old May 17, 2022 | 05:20 AM
FuzzFace2's Avatar
FuzzFace2
I think as a bolt in no. Because the mounting bolts & brackets are all in a different place and don't line up.
Door panels tie into the dash on the later years but they may swap to the earlier years.
Then you have the gauges, they will read backwards IIRC.
Some later speedo are electronic too.
Dave ----
Old May 17, 2022 | 09:35 AM
triorez25's Avatar
triorez25
Dave ----
I knew I'd have to cut up the truck i was worried about space thanks for the info
Old May 21, 2022 | 09:38 AM
Eddiec1564's Avatar
Eddiec1564
It is NOT a bolt in job. The dash mounts on firewall are different. With a wielder that can be resolved. The steering column mounts are totaly different too. That right there was a a deal breaker for me when trying to use a 91 cab to replace my 84's rotten out cab. Alot of custom work was needed.
Doable, yes with some work and figuring. Then if your are going to use the newer fuel gauges, you must swap out the sending units as after 87, Ford went with reverse style function so you got to mod the fuel tank sending units. All other gauges should work as before.
The door panels may need to swapped to newer style dash. Cant remember if its a fitment or style issue there.
DieselDad16
Oct 10, 2021 10:04 AM
BiggBlack02
Appearance & Dress-Up
Jul 21, 2021 05:44 PM
StrokinHer01
Oct 13, 2019 01:09 AM
frankyford
Aug 27, 2006 11:39 AM
