Blend door AC problems
Old May 16, 2022 | 06:38 PM
cbord12's Avatar
cbord12
1st Gear
I have a 06 f-150 lariat with the digital AC controller, Ive been trying to figure out why it has only been blowing out hot air. I’ve replaced the controller, fuses, checked all the wiring, and replaced the blend door actuator twice and no luck, still hot and the actuator won’t turn. Any suggestions?
Old May 17, 2022 | 10:18 PM
steve(ill)'s Avatar
steve(ill)
look at the compressor clutch... does it turn on and spin with the pulley ? Should run for over 30 seconds, then cut out for a few seconds, then engage again ??? If it does, then measure the pressure on the suction and discharge sides... If clutch does not engage, then electrical problem, or no freon. (R134).
TheMilkman00
Mar 1, 2022 07:03 AM
jelloats
Aug 30, 2021 02:28 PM
gpk
Jun 12, 2013 06:17 AM
jt-stl
1983 - 2012 Ranger & B-Series
Oct 9, 2003 12:20 PM
