Rear leaf spring rating on an '86 DRW?
it just occurred to me that I’m not sure if this is a pickup or chassis/cab. It’s a 4WD DRW, and I’ve been told that you could only get bullnose DRW’s in 4WD configuration if you ordered them as a chassis/cab. Is there a code somewhere on the truck that would tell me?
the reason I’m not sure is due to it having a pickup bed on it. I know you can put a pickup bed on a chassis/cab, so this muddies the waters for me.
Look at the 4th digit on the vin. If it's a K, it's a chassis cab. If it's a J, it's a pickup. You could have a 2wd dually pickup that someone has converted to 4wd with a chassis cab front axle. Or you could have a f350 single rear wheel pickup that someone put a dually axle and bed underneath, and put the Ford adapters on the front for the dually wheels. People do it all the time.
I will attach a file that has some numbers on it.
buck_
1978 - 1996 Big Bronco
10-26-2010 11:40 PM
Bern_F150_4x4
03-07-2008 06:40 PM
RawPower
06-16-2005 02:58 PM
