Rear leaf spring rating on an '86 DRW?
Old 05-13-2022, 09:19 AM
__ELC_AMX__'s Avatar
__ELC_AMX__
__ELC_AMX__ is offline
Question is in the title. I'm looking for the spring rating on my '86 DRW, it has overload springs. What is the rear leaf pack's weight rating?
Old 05-13-2022, 10:26 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,789 Likes on 1,444 Posts
3225lbs if it's a pickup. 4500lbs if it's a chassis/cab truck.
Old 05-13-2022, 10:35 AM
__ELC_AMX__
it just occurred to me that I’m not sure if this is a pickup or chassis/cab. It’s a 4WD DRW, and I’ve been told that you could only get bullnose DRW’s in 4WD configuration if you ordered them as a chassis/cab. Is there a code somewhere on the truck that would tell me?
the reason I’m not sure is due to it having a pickup bed on it. I know you can put a pickup bed on a chassis/cab, so this muddies the waters for me.
Old 05-13-2022, 12:26 PM
Franklin2's Avatar
Franklin2
You can't put a pickup bed on a chassis cab truck unless you heavily modify it to fit. And then your wheels would be tucked inside the wheel wells noticeably in the rear.
Look at the 4th digit on the vin. If it's a K, it's a chassis cab. If it's a J, it's a pickup. You could have a 2wd dually pickup that someone has converted to 4wd with a chassis cab front axle. Or you could have a f350 single rear wheel pickup that someone put a dually axle and bed underneath, and put the Ford adapters on the front for the dually wheels. People do it all the time.
I will attach a file that has some numbers on it.
File Type: pdf
buck_
1978 - 1996 Big Bronco
10-26-2010 11:40 PM
Bern_F150_4x4
03-07-2008 06:40 PM
RawPower
06-16-2005 02:58 PM
jor1369
04-08-2005 10:32 PM
Quick Reply: Rear leaf spring rating on an '86 DRW?
