Sponsored by: Real Truck
Electricial problem
Old May 11, 2022 | 11:36 AM
Lehighosprey's Avatar
Lehighosprey
Electricial problem
Dash lite started to flash and lite and slow dim .Took to local parts store told alt bad .Got same alt mps installed and my lite still on and doesn't throw a charge.Need help I'm almost bald from pulling my hair out.
Old May 11, 2022 | 01:20 PM
99powerstrokedF250's Avatar
99powerstrokedF250
What truck? What engine/trans combo?
What light was flashing?
Need a LOT more info than what you're supplying.
Old May 11, 2022 | 01:39 PM
Lehighosprey
Alt problems
1999 F350 v10 changed battery and alt .Not sending any current to battery ,reads same volts at battery and red wire on alt.Need to figure out which wires to test to see if producing voltage.
Old May 11, 2022 | 03:21 PM
Djosbun's Avatar
Djosbun
Your new remanufactured alternator is probably bad, or you misdiagnosed the issue as being related to the alternator to begin with.
Only new Motorcraft alternators should be used unless you don’t mind installing/removing bad reman units.
— Dave
kennyray
25
May 18, 2014 02:06 PM
fruth04
1997 - 2003 F150
May 2, 2006 09:27 PM
725franky
30
Dec 12, 2005 06:17 AM
golfotter
Jan 19, 2004 08:50 PM
