Debating about getting the trailer drums turned.
Most drums use to have enough meat on them to be turned at least once, are trailer drums the same?
Anyone know what the thickness of a new drum is by chance?
On side note, last time I needed something turned it seemed like every parts store offered it as a service, not so anymore. Local O'Reilly only has 1 guy able to do it during banking hours.
I get it though, rotors are throwaways and drums are old tech..
My drums were 15 years old and I'm the third owner. No idea about service history. Nobody local turned drums anyhow. I upgraded to heavier duty drums and bearings. Virgin races seemed like a good place to start over.
Why do you think they need turned? Might just be some imprints on them, causing a pulsing sensation. IMO, I would take apart, inspect brakes, light sanding to brakes and drums, clean out with brake cleaner, repack bearings, reinstall, adjust brakes for a very slight drag.
Love how you jump to conclusions and assume..
because they are rusty and need turned/replaced
SMMFH
it isn't a fsckjng imprint!
now does anyone know ?
I really dont care if you just bought new or about your third cousin . Simple question.
how much material is available to turn
SMMFH
My drums have the max diameter stamped into them.
Speaking of turning, I had a machinist turn the face of the drum where the magnet rubs. That and new magnets really brought the brakes to life.
Well, maybe if you had included the additional info in your initial post other members wouldn’t have jumped to a common conclusion, and you wouldn’t have had to respond in a way that makes you seem grumpy enough to ignore. But I’m a nice guy and I’ll try to add a little here that hopefully won’t cause you any further frustration.
Many drums will have a minimum thickness stamped/cast on them. To complicate things trailer drums with electric magnet brakes would also need the magnet contact surface turned, which will of course reduce the number of shops able to do the job. If they are so rusted that a manual cleanup with sandpaper won’t save then I’d be looking at new drums.
I thought all drums & rotors had a minimum thickness stamped/cast on them?
Other wise how would you know if they are still any good?
I was going to ask if you found any place that still turns drums & rotors as did not think any one did any more?
I have not looked around me but I think its slim pickings.
Also as said the magnet side would need turning too.
I think I would get on Etrailer's site and order me some new drums & magnets maybe even shoes and be done with it.
Unless you have a trailer place close by. There is a RV trailer sales & service a few miles from me I just dont know what all he may have in stock?
Dave ----
That's how I bought almost all my brake/bearing supplies. The local trailer store had what I needed at better prices than I could find online. It wasn't a completely painless experience, but I definitely saved money and supported a local business.
Dave ----
Same here, we have a good trailer parts shop about 20 miles away (Eastern Marine) and that’s where we bought our new 7K axles and springs when we upgraded our TT’s suspension, much cheaper than online and shipping.
I'm aware of the magnet surface and if I thought it was bad I'd just get new drums because I am also aware few shops have the machine to do that cut.
The question was about thickness of drums, not about doing maintenance on them, replacing bearings,seals or repacking them or anything to do with that.
Why is it so hard to stick to the question instead of giving opinions that has nothing do with the topic?
Yes I know about the tolerance stamp for minimum, I was not aware they also stamped the max thickness as well, I'll have to look for that stamp.
I only asked to save the hassle and be told they can't turn them. and while it isn't relevant why it's a hassle it's because I don't want to leave the
trailer up on jack stands for an extended amount of time waiting on the drums to get turned. They can't promise a turn around time.
The rust is thick enough that I want a machine to clean the surface up if possible. I thought it was a straight forward question with a straight forward answer.
It's fine, I'll do what I was planning and go from there, again thought maybe I'd get a straight answer. which is kind of rare on here tbh.
For clarity, drums are labeled with maximum diameter while rotors are labeled with minimum thickness.
It's getting to the point where you have to know a guy to get drums and rotors turned. A couple parts shops near me used to do them along with flywheels but the guy that did it a few times per week retired.
I have a brake lathe so that I never have to look for someone to turn them. Pure convenience.
My experience, operating one for 35 years, is that truck rotors and drums have plenty of meat to turn. If you were to measure the new ones that the parts store is selling, your freshly turned parts might be thicker.
