Help choosing alternator
Old May 9, 2022 | 09:30 AM
RigCity's Avatar
RigCity
Unfortunately the motorcraft 110 alternator is on national back order. The dealer said they can order a 6.0 140 amp alternator but they said there are a ton of 140 amp models on the computer. Idk if antic those work with grinding down the bracket or only a few of them. Can I please have some recommendations on a replacement unit. Looking for a dependable unit vs budget model.
Thanks
Old May 9, 2022 | 09:48 AM
Kwikkordead's Avatar
Kwikkordead
Your quest would be greatly helped if we knew what make, model, production date, engine, etc was listed in this post.
Old May 9, 2022 | 09:51 AM
RigCity's Avatar
RigCity
2002 7.3 250
Old May 9, 2022 | 09:52 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The best alternator you can get for our engine is the Leece Neville at ~$400. See link below for details and history lesson.
Link: https://www.ford-trucks.com/forums/1...tle-input.html
Apparently FICM Repair is an authorized dealer as well, but I only recently learned this.
Link: https://www.ficmrepair.com/index.cfm...rod/prd339.htm
The larger case alternator will require a slight amount of grinding of the bracket, but it is minimal. Other than that, you can take your chances with a 6.0L alternator from a parts store. Sometimes they are great and sometimes they are garbage.
Old May 9, 2022 | 11:13 AM
udsuth78's Avatar
udsuth78
The Bosch AL7606N is what I went with. Listed as140 amps and only required a little grinding in the saddle and swapped the pulley. If your set on Motorcraft you could try cross referencing the Bosch number.
Old May 9, 2022 | 12:05 PM
Dan V's Avatar
Dan V
I used a NAPA 1N-3169....a couple minutes with a 1/2 round file and you're good to go.
Old May 9, 2022 | 12:40 PM
RigCity's Avatar
RigCity
I ordered a new motorcraft one online after locating a ford reman for the same price. Of course after ordering I saw it's the "service design" which the dealers told me to try to stay away from parts with that designation​​​​​. Kind of annoying but not much to do at this point besides get the truck operational. Thanks for the replies.
Old May 9, 2022 | 01:10 PM
Sous's Avatar
Sous
FTE Emeritus
What was the reason given as to why you should "stay away"?
If you are not comfortable with the online order, you most likely still have time to cancel it.
Old May 9, 2022 | 01:29 PM
RigCity's Avatar
RigCity
They said it's a part built to a lower standard it comes up more often dealing with brake parts. Of course I'm too ocd to not cancel the order and re pay the shipping for the motorcraft reman FML lol
Old May 9, 2022 | 02:10 PM
SteveH-CO's Avatar
SteveH-CO
I am running a TYC (all new, Chinese) from Rock Auto. Purchased in 2013, has always worked well. I bought it literally as an experiment to see if a new Chinese product could work well without issues. I don't really trust anyone's reman....
Rock Auto shows the Motorcraft 110a in stock for $187 + $20 core.
Old May 9, 2022 | 05:21 PM
brian42's Avatar
brian42
Veteran: Navy
TYC is OEM replacement for lots of stuff. I haven't used them for mechanical parts but have had great luck with other parts (trim, headlights, mirrors, etc) as they are OEM-spec and are of good quality for the parts I have used, plus they were an exact fit.
When I replaced my alternators I went with the larger 6G (6.0L) case. Grinding was minimal as Sous said and the aluminum in that bracket was easy to grind.
I bought these and was very happy with them (I went with 140A as I had duals alternators): 6G Extra Heavy Duty Output for Ford POWERSTROKE Diesel (alternatorparts.com)
Reviews are hot and cold for him. I had a good experience while some did not.
Old May 9, 2022 | 06:30 PM
RigCity's Avatar
RigCity
I remember my first time buying "ford" u joints stamped spicer all over lol will be checking that out for some other parts
Old May 10, 2022 | 12:13 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I ordered a new motorcraft one online after locating a ford reman for the same price. Of course after ordering I saw it's the "service design" which the dealers told me to try to stay away from parts with that designation​​​​​..
What is the "service design designation?"
Old May 10, 2022 | 06:14 AM
FordTruckNoob's Avatar
FordTruckNoob
@RigCity , if you are interested in the QuickStart alternator that Brian42 mentioned, I have three along with the external rectifier I can let you have. They are all used, two are in working order and one needs rebuilding. I stopped using them after I switched to a Leece-Neville.
Old May 10, 2022 | 08:14 AM
Sous's Avatar
Sous
FTE Emeritus
He provided a very, very brief explanation in post #9.
